Good new tyres will be going on hopefully at the start of next week after I get it registered. Compliance put ten year old rubbish on it. It’s ridiculous that compliance workshops can put such unsafe crap on a car.
Still after an air box and snorkel if anyone can lend me one.
Good new tyres will be going on hopefully at the start of next week after I get it registered. Compliance put ten year old rubbish on it. It's ridiculous that compliance workshops can put such unsafe crap on a car.
pretty sure BITSUS is selling one if your desperate
  • Like 1
  • Nope 1
