Hey guys need to borrow the following to get me through regency
R32 standard catback and cat
R32 gtr standard computer
R32 gtr standard suspension
R32 gtr standard wheels with goo enough amount of tread to get it passed, all up will be needed for like 1 day cheers
0401475561
Hey Guys i am looking for a aftermarket intake manifold for a NEO RB25DET, will consider all options ie- complete with throttle, inj &rail, just manifold, new used ect ect Show me what ya got.
SMS Details and pics to 0422444532
Sorry wrong section..oops :stupid:
0401475561
hi i got a set of r32 gtr wheels. pm me if you still need some
Hi Guys,
Need to borrow 1x Early and 1x Later R32 GT-R, and 1x R33 GT-R for some product fitment testing please? I'm Located in Hope Valley, and willing to share beers one evening after work, or a Saturday to test-fit some new products I'm making ;)
Prefer un-modified examples, or at least with factory inlet piping, and stock or mild turbos.
Let me know if you are able to help,
Cheers,
Nigel
  • 3 weeks later...
