Well this is the 1st I've heard about the A050's (just looked them up and they sure look weird!)
I'm not sure where you are located but you'll need to contact your local Advan Motorsports Tyre centre - generally there is only 1 per state. (If you want to know where to buy each R comp in each state grab a copy of the latest Tarmac Magazine - it has all the tyres and state suppliers listed)
For example in Vic for Advan tyres it is Traction Tyres - http://www.tractiontyres.com.au/
But I'm not aware of these being here yet so I guess there'd be bugger all feedback on them. But you can be sure when they do come they will be $$$$$$$$$ - so still I'd suggest the RE55's will be the ones to choose.
For whatever reason the RE55's appear to be much cheaper on pricing than almost all the others - in the larger sizes anyway. Plus they have a reputation as being the quicker tyre.
But maybe Yokohama has made a gain....
As an aside I was watching the utes from Wanneroo on the weekend just gone (Go the yocal Grant Johnson) and amongst the PR blather from one or other of the Jane family was the claim that the new 18" tyre/rubber combination was, relative to the 17's worth over half a second a lap. Any comments?
After they changed almost all of the the suspension settings to suite the 18's ie; they didn't just bolt them on and go 0.5 seconds faster.
Cheers
Gary
The RE55 would get my vote as well.
I have used both RE55 and AO48's (so not a true comparison) but i will never use the advans again. The advan is more expensive, seems to suffer more with heat cycling and just doesn't seem to perform if the pressures aren't spot on. I also found that they didn't feel too nice under braking as they got older. They just didn't inspire confidence.
Where as the RE55's i used on the weekend are half worn on the front (3 tracks days old), well past the indicators on the rear (they have done 6 track days in the last year) and i generally just make sure they are around 34-36psi hot after the first session and don't touch them for the rest of the day. They are pretty noisey, not that it matters.
I pulled another second out of my wakefield pb on the weekend, so i would say they are performing well enough for a weekend hack like me. And as they are still cheaper than most other semi's in 235/45-17 it's a good sweetner.
  • 10 months later...
digging up an old thread but.....
This weekend some of the Pro class were using the soft compound of this tyre and getting some good results, it is really only a sprint/hill climb tyre but speaking with the gordon levin team they are getting the medium compound stock in around a months time.
Being a lot newer desigin the ADVAN A050 it will be interesting to see what peoples thoughts are once the medium compound becomes available,
matt
  • 7 months later...
matt
Digging it up once again.
Anyone got any more feedback!?!?
I have just ordered a set of mediums for the Evo, looking forward to comparing them
to the times i was getting on the SR2 RE55s.
A few Vic guys are running them and I've heard nothing but good things from them.
I've also spoken with an STi driver, and while he really liked the tyre they had quite a fast wear rate on his and a customers car. The owners of the lighter R32 and S13's I'm referring to above have found good wear though, so I'm not sure. I'll probably be trying out a set after my RE's are gone.
  • 5 months later...
Dig this up again....
I'm hearing very positive things.
Anyone with direct comparable experience to RE55's that can comment?
If you're from sydney. Go to superlap. It will answer your question.
  • 1 month later...
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
