Hey guys,
was just wondering if its possible to use this:
http://cgi.ebay.com.au/R32-Skyline-RB20DET...1QQcmdZViewItem
as a possible upgrade for my R33 as opposed to doing something like a Power FC. I kno the R33 chips cannot be flashed like the R32 ones, thats why i was thinking of exploring this option.
Edited by YDUTRY4
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/
no but there is a rumor that Tilbrook auto and dyno may/can re-map standard r33 computers so give him a call 8261 8619
:P Holy shiezzer, for real? Im calling rite now, if thats a yes then FMIC & this are my next steps of tuning!
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3894430
Jeff from The Speed Lab can tune an R33 ECU - but it just requires a modification to the ECU. From what I understand the R33 ECU requires some components to be changed (adding of a daughterboard I believe) therefore will add a couple of hundred on top of the normal tune cost...
so if it's $600 for an R32 tune, expect about $800 or so for the R33 tune :P
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3894636
Well actually YES
Ring Jeff, He can Reflash R32 and Z32 ECUs and remap them for use in R33's. It's cheaper than remapping the R33 one as you don't have to buy the daughter board.
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3895466
Although you CAN use the R32 ECU, why would you skimp on ~$200 to remove extra driveability?
I just don't see the point in doing it half assed.. you say you wont notice the loss of mid-range, but why lose it at all? :D
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3897440
I spoke to Jeff around lunch time and he reackons that yes you do loose a little bit but its not noticeable.....and the power gains is pretty impressive.....so i am going with that option...dont worry i will still have my stock ecu sitting at home just in case
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3898159
yeah thanks simon.....thats the same answer i got from Jeff.....i am going to get Jeff to do a dyno run on shoot out as the car is and then one after the tune and then give me the 2 print outs......
https://www.sau.com.au/forums/topic/220868-r32-remap-chip/#findComment-3900420
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
