Hey Guys,
I have a 1990 R32. My speedo all of a sudden dropped out, and my hicas light has come on and the power steering is heavy. when you first drive the car for the first 5-10 mins all is good, steering is fine, then the light comes on and the steering becomes heavy. i have checked power steering fluid and topped that up. Just wondering if anyone knows what the problem may be....... the speedo esp is rather annoying!
Cheers!
Pammy <Queen R32>
Sounds like you've snapped the little needle on the end of the speedo cable where it goes into the back of the dash.
Exactly the same symptoms as when mine snapped. You can get a new one from Nissan but I can't remember how much it cost, don't think it was too outrageous though :P
Thanks for that!!!!! And would that make the hicas light come on and the power steering not work properly? If i were to call nissan and ask them for the needle on the end of the speedo cable that goes in the back of dash will they know what im on about? haha
Thanks heaps!!!!!!
Also, do you nkow where io would go to get it installed?
Thanks heaps!!!!!!
Basically the HICAS light is coming on because the HICAS ECU is throwing up an error due to lack of signal (it gets a road speed signal from the speedo which then sends it to the ECU). Our cars also have speed sensitive steering which kicks in at about 80kmh (light steering for low speed and parking etc, heavy steering for high speed etc), if it doesn't get a road speed signal or a steering angle signal, after a few minutes it will throw up an error and your steering will go heavy.
Unfortunately you can't just buy the needle as it is integral with the cable so you need to get a whole speedo cable. Head to Northside Nissan and specify the year and model of your car and they should be able to sort you out, when I got mine they had one in stock so it was all good..
Any competent mechanic who knows skylines should be able to do it. I did mine myself when I put the 25 box and 280kmh dash in.
Good luck :P
Spot on! Cable broken.
Mr Keets R32 had the same problem last week. New cable, all fixed.
Northside is the palce to get it, probably cost around 120-130ish. It will take about an hour to install.
Good Luck
  • 2 months later...
Good luck :O
Hi, I'm having this same problem too.I've tried many times to reassemble the speedometer to the cable but the needle either doesn't contact properly with the meter or the internal part of the cable sank in.Do you have any idea how to secure the needle to the cable? There's also a spring inside the needle..it dropped out initially but I put it back, still won't work.Please help!
Edited by EJD
just one thing though northside nissan only stocks the GTR cables you can use them but they are too long you have to get the GTS-t one ordereed in, i got the gtr one and it works but doesn't look very good under the car
Hmm that explains why my cable is so long.. I was changing gearboxes at the time so just assumed it was a difference in the boxes..
You can get them to order you the right cable though.
Edited by bubba
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
