Hi guys ive been trying to get some good sites for getting a new body kit for my S1 R33. Its not as easy as i 1st thought, you guys know any good sites???
Hi!
Are you in Sydney?
It's a good idea to make sure they fit before you pay!
One firm that'll do this is www.jsai.com.au and talk to Josh
Got my R34 GTR side skirts and rear pods there, and I lined them up with a semi-fit before paying.
Service is very good.
He's at 65 Alexander St Taren Point
He makes exact copies of anything Nismo too
Cheers,
Terry
  • 1 year later...
I always used Taka Kaira to look up kits to see what I liked.
http://www.takakaira.co.jp
we do a lot of kit fitting, painting etc at driftline (campbellfield, VIC, driftline.com.au), there's a bit of stuff in stock, but most of the its we order in. Not much we can't get tho.
Hey anyone know a good site/ place that is located in victoria? Preferably close to melb
Thanks
PSI parts - Dale or Shane
www.psiparts.com.au
Email: [email protected]
Phone: (03) 9791 2129 or 0411 237 219
Location: 22/22 Dunn Crs, Dandenong, Victoria 3175 Australia
powerplayimports.com.au
huuge range of stuff there :thumbsup:
the rest i usually look at have pretty much been mentioned.
if your looking to import one importmonster has a good range .. lets you use the yahoo auctions n stuff.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
