Hey all,
One of my headlights recently blew the other day, they are the stock r34 xenons, yesterday i opened up the headlight so i could replace the bulb but when i opened it i had seen that its not a normal bulb you just unclip and take out. its a long thin bulb with magnesium strips in it. does anyone know if they have the same type of bulb in? the headlight has no socket for a bulb it just has 2 wires going into the bottom of the bulb in there. i checked the other side and its exactly the same. does anyone know where i can get the headlight changed?
Thanks
https://www.sau.com.au/forums/topic/221800-r34-headlight-bulb/
how much do they cost? and where abouts from australia can you get them from apart from Ebay? i think mine is either 6000k or 8000k its blue and there pretty bright but not sure lol. does it matter which one i get or do i have to get an exact one?
Edited by b3za
You would be able to get them through Autobahn, not sure on price.
Can you get a picture up of the plug to the globe? I have a feeling that the compliance company changed it over to take halogen globes, but the previous owner threw in those cheap HID kits. Not genuine R34 HID globes, therefore not being D2R (or what ever it really is).
Also keep in mind you're best replacing both of them - as they do sorta change color over the life of the bulb and if you only replace one you can end up with slightly different shades/colours in the light (at least in my experience)
Jenna
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
