Hi all,
I also had problems with my HICAS with the light coming on after start up but would go away when you turn ignition off then on again once car warmed up. This occurred around 6 months ago. In the last 2 month the HICAS light would suddenly come on during driving and the steering would go heavy. Any who, it ended up being the HICAS control module. I replaced a leaking capacitor and cleaned up all the corrosive liquid on the PCB. Car is a 93 R33 gts-t.
Hope this helps..
hey..
my hicas light comes on after driving along the highway for any more then about 5-10mins.. doesnt go off until car is turned off. but normal around town type driving it never comes on.. also when its on after driving on hughway the steering doesnt seem to change at all..
any ideas?
Do you have an after market steering wheel?
Have you tried the diagnostics?
Can you replicate the problem every time you are on the highway?
yes i have a "personal" brand steering wheel..
nothing shows on diagnostics..
yes problem happens everytime without fail..
Edited by 02_FNE
It maybe your steering wheel that is causing the problem. Not sure what type of angle sensor used but since the control module is not showing an error code the problem may only be minor. Has this light come up ever since you had the steering wheel replaced?
not sure mate, i got the car with this steering wheel already in it.. as far as my memory recalls its always done it..
i thought it was strange that it doesnt seem to change the actual steering at all..
my understanding is that that brand of steering wheel is a nissan owned company or brand or something along those lines..
There are a few threads on this site that talks about the HICAS light coming up after steering wheel/BOSS has been replaced. I think they also say that it only comes up after long straight driving as is done on the highways. The problem in your car should be easily sorted as the symptom is easily replicated.
Buy!
  • 2 months later...
  • 1 month later...
hey ummm i have a question
my HICAS lights turns on
EVERTYTIME , at the exact distance of 10km or so of driving
i time it the spot where i usually go to work n back home
it always turns on at the same area.
so what's wrong with it?
HICAS isn't really a major problem is it?
cheers.
SAME HERE! no idea what it is though? the diagnostic never works for me. i'm assuming it's the steering angle sensor because i can't enter the diagnostic. i'd assume the steering angle sensor is what puts it in diagnostic mode with the left right turns and the brake pumping. when you exceed 80 k's does your steering wheel turn one way slightly and then correct itself when you go back below 80? mine does. until the light comes on. then it stops...
Steering wheel 'rolling over' at speed (increasing as speeds pass 60kph) is what happened on my car when the steering angle sensor was mis-aligned with the wheels.
If you cant answer the diagnostic mode at all - sounds like your steering angle sensor isn't working though. Do you have an aftermarket boss? Nissan dealers with CONSULT should be able to get into the HICAS diagnostics and pinpoint exactly what's wrong (that's what I did).
  • 3 weeks later...
  • 1 month later...
i did the test on my r32 gtr and i got 4 quick short pulses followed by the hicas light staing on for afew seconds...
then after that i kept my car on and still in the diagnostic mode, and it did 4 quick pulses followed by the hicas light staying on for a few seconds
what did it pick up as been the fault ??
the hicas is giving me the shits i need to sort this out ASAP !!!
hope someone can help me !
thanks
someone have a look at my thread and see if you can offer any advice. much appreciated.
http://www.skylinesaustralia.com/forums/Hi...ng-t312556.html
i'm thinking hicas ecu may be faulty. it has the trademark 3 capacitors with a very slight stain below them that may indicate some previous leakage.
Edited by Munkyb0y
  • 5 months later...
  • 4 weeks later...
Must be a different problem with mine.. it has had the problem since i bought the car (with standard steering wheel) and still has it with my after market one..
might be a dodge connection somewhere..
  • 1 month later...
My problem, which I've had no luck in getting anyone to know what I'm on about:
Sometimes when I turn on my car (not all the time, it didn't do it for around 3 weeks but now it's about every third time I turn it on), the HICAS light stays on. Solid. The whole time it's on, it feels like I have no power steering, eg. the wheel is sluggish and hard to turn.
I've checked fluids. That's all fine there.
I've got a MOMO steering wheel, but the HKB boss kit (HKB = HICAS compliant), so there's no problems there. If there was a problem there, it'd be permanent, not just every now and then.
Anyone got any ideas? I'll be performing a diagnostic this weekend, so I guess I'll post up the results of that then rip the car apart till I can find it. Then lock the damn thing down anyway.
Hey all,
Ive got the same problem where once the HICAS light is on the steering becomes very heavy but after I switch of the car and go to switch it on again all my electrics fail there is a wire that got fixed by an R.A.C man and once i move that around the electrics come back on and there is no more HICAS light on this is only recent and is becoming more frequent.
Im not sure whats going on with the car but if anyone knows of any solutions would be greatly appreciated
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
