I'm after peoples experiences on how much dyno time and tuning cost to get their 30DET's tuned to the point where they are satisfied.
I have a 25/30 with PFC+FcDatalogit good for 350rwkw and wanted a rough of idea on $ and time needed for tuning.
Edited by Alf
https://www.sau.com.au/forums/topic/222242-tuning-the-30det/
i usually find that after 2 and half hours i am wasting time on the dyno and should really get off it... after doing a full tune.
have done full ecu remaps in less then 90 minutes but they were close to stockers
take it to a tuner with a dyno, there's no substitute for a twin cam head and ecu that was never meant to have a 3litre block under it , your asking for trouble trying to DIY it.
fill ya car up with 98 octane and about $800 for a full map and tune.
this will get you the safest maximum hp for what the engine is capable of,
not only that, the tuner can tell you details, like injector cycle, fuel pressures, timing, air flow,
giving you first hand knowledge of how close to the limit the sensors are, eg out flowing the afm, leaning the engine out due to low fuel pressure, and the duty cycle of the injectors and what % they are running at,
exhaust temperature's which give a good indication of timing and air fuel ratio, as the more advanced the timing the hotter your turbo's will run and the greater the risk(for all you people still using ceramic turbo's) of sh*tting themselves.
that is just scratching the surface,
Sorry, would have to disagree with most of that. Firstly it is basically rare for a dyno shop to use an EGT to tune. Secondly an rb30 with a twin cam head makes no difference to the tuning, and no dyno operator will guarantee that is the most safe power, unless they built the motor. All the other bits can be just as easily monitered using the datalogit(actually thats what the dyno tuners use to moniter the sensors). I would get accustomed with the tuning gear, and do a street tune, and then hire a dyno for the full throttle stuff when its run in.
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
