I hate people who lie about thier cars same thing happened to me when i had a ma70 supra....the guys said it was fully rebuilt and transmission had been changed.....i later found out 3 weeks later when my motor blew that it was the orginal engine and then 2 months later the tranny blew it really pissed me off.....as for my skyline if i was to ever sell it i would provide alot proof and reciepts that my motor has been rebuilt and everything thing that has been put in the car has reciepts from the forgies to the injectors so that everything is legit....
farque me, how ironic...
lol think thats bad i bought a RB25 with no dip stick....and the owner still thinks hes in the right and thinks he told me about the no dip stick :happy: if he told me i woudln't of bought he also told me its rebuilt blah blah blah i danno if its true but hte motor hasn't skipped a beat touch wood hehehe but yeah liars just makes me want to throw some pistsons too :D
we all no of some one in the circle of friends we have that gets the stolen fones, into the drug scene, rorts inocent people blah blah blah, how come day in day out these kunts(friends) get away with what they do and yet the people getting ripped off just say to them selves" karma will get the guy back".. lol load of crap, my mate has been how he is for years and yet still smiling and doing what he does...
if i was to rort some1 for extra dollars, i no with my luck i would cop karma like no1 has b4... i think if your really not a bad person and you do something wrong karma will f**k you just to teach you its bad, but if you are a bad person and have been for all your life then karma wont teach you shit, i say pistons for all rorting kunts and a tailshaft threw there mums head....
just makes me mad, as having the feeling of being ripped off to me falls in the same catagory as if your mrs cheats on you..
Im with Beer Baron. Until someone can show receipts for parts and work (or only parts if work done themselves) then no rebuild.
LOL @ buying an engine and just believing whats done. Those people are as stupid as the seller is dishonest.
Oh and guys, my RB25 is fairly worked. CP Pistons, forged rods, ported head... :( just cant find the receipts :)
I've known a lot of people like you describe...but none are my friends, some were. I'll say g'day if I bump into them, but thats it..no beers, no laughs, just f*k off..
Buying stolen goods is as bad as stealing it yourself, helping to create a stream of income for scumbags = not a good idea.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
