hey all
madaz r33 has given me a good plan for the cruise, seeing as we're all from the burnie area apart from him, he suggested that we start in devonport then have a run through some of the back roads on the way back to burnie then cruise through burnie itself. let me know what you guys think
cheers adam
  • Replies 72
Posted Images
Keen for anything. Back roads are for tractor's tho imo
^^ Watch you talkin bout willis? my g/f's parents used to own property at natone, the drive up from Minna road through natone and stowport is sick imo. (or even going towards burnie and turning up the hill as just get into burnie that has the dogs home there, forget the turn off road name) I used to wind my old Rx7 out on some of those straights(although speedo stopped at 180 and i'm not sugesting we do that!) heaps of wicked sweeping corners, its a good drive along that area. Mind you on the very odd occasion an old farmer would be putting around on his tractor, all of the farmers were pretty cool and always pulled to the side asap to let me through. Damo
Edited by madaz R33
well i think everyone has decided cruise through burnie and up some back roads. as for speed just doin 100 through some of those corners is fast enough to have some fun. i mean a day at the track would be fun but it's a long way to travel
all good, lets do it, most people on the NW would be moderately happy with the suggestions, it will do for our first NW cruise, Elaborate on further cruises if people show up to this one and its a success.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
