what should my car run E/T with good grip
R32 gtst mods are rb25 conversion ,fmic 600,300,70 hypergear kit ,turbo back exhaust 3"
blitz bov pod with cold air intake with head light out 12 psi with turbosmart boost T
tyes 255/40/17
should it do low 13
what do you guys think about a 12.9
i bet a typhoon they run 13.7 stock
Edited by RB SANDY
https://www.sau.com.au/forums/topic/222538-what-should-my-car-run-et/
u could look at a mid 13 to low 13 u mite be pushing any 12 but it all the driver and a good take off u could hav 2 drivers same car 1 get a 15 1 get a 13 so noone could giv u a good answer but the car should be capable of a mid 13
it is a how to guide but it is the driver. u could get a better time but have more power in a lighter car your next prob is traction. i got a 32 gtst when i ran mine had about 190 rwkw and ran a 13.5 but bad traction launched at to high revs. does the how 2 guide tell u what to launch at because what if 2 drivers do differant launch 1 at 4g and 1 at 7g they both goin to get 13.4. it just doesnt make sense but best way is run it u mite surprise yourself and get a 12 i hope u do. just run it a thew times each launch at diff revs to test it out
lol 40 profile on 17inch rims is only gonna get your mates going "pwoaahh sandy you got no traction down the quater" lol, get some nice street/racing slicks, and then what ever you run will only improve on the launching department, as your traction department will be covered...
when you do end up taking it out, post your time on here. i keep meaning to take mine out, but little things just keep going wrong.
got a boost leak at the moment.
before that it was the rear camber
and before that it was the clutch
and so on and so on.
never anything major, but enough to keep me away from the track.
my younger bro ran a 13.3 with simular mods to you in a r33 with a 2.0s 60 foot time.
If you can drive it hard and launch it well (his tyres were shit so theres no reason why you can better his 60 foot time), theres a good chance for a very low 13 pass. Put slicks on and launch it hard and a high 12 should be on the cards.
Edited by R34GTFOUR
I'd say mid 13's should be on the cards at least - From what i remember a few years back when i got a seat in that thing it was mighty quick and had me smiling for a while :happy: BTW, I'm your mate Steve's cousin if you remember.
I'm hoping to tap into the 13's with my car:
stock RB20
+ 3" split dump&front / high-flow cat / 3.5" cat-back
+ FMIC
+ bosch 040 pump
+ APexi power intake
+ remap (boost restrictor/speedcut removed + ignition timing advanced with new fuel map)
160kw atw before remap, was quoted a 10-15kw gain after remap & between 10-12 pound ATM - car running extremely well.
Cheers,
Steve.
years ago when my 32 had an rb25 with 190rwkw std rb25det unknown ks 3in turbo back, pwr intercooler,microtech ecu 11-14psi no difference. run between 13.2 to 13.4 all day on 225 street tyres 108mph i think.would just break into a 12 with m/t street slicks id say
got walbro myself. nice and quiet, and also reaches to the bottom of the tank, so can use the full tank of fuel, as oposed to 3/4 of it.
as soon as i find this damn boost leak, will take my car down to the quarter. expecting mid to high 13's....
at the moment replacing the front bushes, so won't be fixing the leak for at least a month or so. budget just does not allow it.
You wont need 230 at all.
I ran 12.9's @ 109mph all day long (lots of practice and i was very consistent back in the day)
And that was with 220rwkw, RB25 in a car over 1400kg (HR31 GTSR)
This was using 225 Simex tyres, nothing special, nothing thick.
R32 is lighter by a reasonable margin, it should be able to do it with 200rwkw.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
