Of course a car with no mufflers, ext gates not plumbed etc etc will do it.
Road cars, with a level of noise legality surrounding noise, ride height and so on, simply not going to happen
You've got more issues with a 4" exhaust and ride height, then a 3"... And I was talking, perfectly legal road going cars. Not those running screamer pipes or anything.
Also, not every 400RWKW car runs turbos or forced induction either.
But I have seen FI cars, run with 400RWKW and 3"
anyone with there car sitting stupidly low worry about exhaust height obviously hasnt taken much notice to there suspension except for it sits hektically low
with my twin 3" into single 4" i had on my silvia at the lowest point as it passed under the diff i had 110-115mm clearance from the pipe to the ground.. and no the car didnt sit like a 4wd
My reference to ride height, was in response to mr Nismo.
And I'd be saying your car was one of the nearly stupidly low cars if you only had 110 - 115mm of ride height. Seeing how the legal limit, when completely empty, is 120mm, and when maximum loaded, is 100mm... You had a max of 15mm before you were below legal limit... Something I'd call low.
I was simply pointing out, if you read the post I quoted, that a 4" gave more ride height issues then a 3"... Whereas, mr Nismo wasn't trying to state ride height issues with the person running a 3"...
wat you didnt read was were i said the lowest point of my exhaust was 110-115mm clearance and that was right were it went under the diff.. car never had any scraping issues and was far from "stupidly low"
the car even made it up my driveway which was almost impossible for any car that wasnt factory height
the limit is 100mm regardless, ive been pulled over and spoken to by police many times ( mine is 102mm) theres no rule for 120mm empty... i wouldnt call it stupidly low, never been held back by a single speedhump yet, just need to know how to take it and go slow,
i got a 4" turboback exhaust as well
my mums stock bmw is 115mm from its lowest point, wouldnt really call that level stupidly low these days
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
