  • Replies 68
Posted Images
Yeah, i think theyre 3/8 in diameter or something like that. They couldnt be in a better place really. Silly to run braid or any other solid line under the car if these are unused.
Shaun.
Whats wrong with just using the standard fuel lines under the car? Thats what i did, my setup is the blue skyline in the first post of this thread.
Edited by Gts30t
Can you remember the exact fittings you used to hook the braided lines up to the stock hard lines?
  • 3 weeks later...
That was my first thought, however I find that most of the time it looks really messy or disorganised. I'm thinking of running them underneath the fuel rail through cable holders (similar to what's used for computer cables or home entertainment cables) so that I don't have zip ties and plastic conduit going everywhere.
  • 3 weeks later...
Some very serious filtration going on there.
Are you running one tank for methanol/race fuel and the other tank for normal duties? As it looks like you have a distribution block that links to the fuel lines that run underneath the car?
u guessed it!
the sard surge tank is connected to the standard fuel tank which will be used for ur normal every day 98 octane
the fuel cell will be used for race fuel
the car is setup so it can swap between different fuel's via a switch inside the cabin
we are able to do this because the haltech E11v2 allows us to hold more then one tune map
so with a flick of a switch we can go from street mode to race mode
the wiring involved thats going into a setup like this is just mind blowing
the fuel cell is a custom item which we blue printed from the sard surge tank
we bought the sard surge tank from hi octane and copied its design and built our fuel cell from it
so not only is it a fuel cell its also a surge tank all in 1
the filler cap and lid are all CNC machined from billet
we will also be making our own sard surge tank copy's which we will have on the market for less then geniune sard items and they will perform just as good
  • 4 weeks later...
  • 10 months later...
Fuel system i recently did for a mates 33gtr im building.
For the fuel pump wiring, i used 2 30amp fused relays, 1 for each pump. Power is connected straight to the battery, and the trigger for the relays is spliced into the factory harness, its the wire that goes down into the fuel tank, its a switched 12v that powers on when u flick the key, easy to find with a multi.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
