  • Replies 68
Posted Images
Yeah, i think theyre 3/8 in diameter or something like that. They couldnt be in a better place really. Silly to run braid or any other solid line under the car if these are unused.
Shaun.
Whats wrong with just using the standard fuel lines under the car? Thats what i did, my setup is the blue skyline in the first post of this thread.
Edited by Gts30t
Can you remember the exact fittings you used to hook the braided lines up to the stock hard lines?
  • 3 weeks later...
That was my first thought, however I find that most of the time it looks really messy or disorganised. I'm thinking of running them underneath the fuel rail through cable holders (similar to what's used for computer cables or home entertainment cables) so that I don't have zip ties and plastic conduit going everywhere.
  • 3 weeks later...
Some very serious filtration going on there.
Are you running one tank for methanol/race fuel and the other tank for normal duties? As it looks like you have a distribution block that links to the fuel lines that run underneath the car?
u guessed it!
the sard surge tank is connected to the standard fuel tank which will be used for ur normal every day 98 octane
the fuel cell will be used for race fuel
the car is setup so it can swap between different fuel's via a switch inside the cabin
we are able to do this because the haltech E11v2 allows us to hold more then one tune map
so with a flick of a switch we can go from street mode to race mode
the wiring involved thats going into a setup like this is just mind blowing
the fuel cell is a custom item which we blue printed from the sard surge tank
we bought the sard surge tank from hi octane and copied its design and built our fuel cell from it
so not only is it a fuel cell its also a surge tank all in 1
the filler cap and lid are all CNC machined from billet
we will also be making our own sard surge tank copy's which we will have on the market for less then geniune sard items and they will perform just as good
  • 4 weeks later...
  • 10 months later...
Fuel system i recently did for a mates 33gtr im building.
For the fuel pump wiring, i used 2 30amp fused relays, 1 for each pump. Power is connected straight to the battery, and the trigger for the relays is spliced into the factory harness, its the wire that goes down into the fuel tank, its a switched 12v that powers on when u flick the key, easy to find with a multi.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
