  • 3 weeks later...
Hey PRIMO,,,,aern't you in the wrong section buddy........Sounds to me like you should not be Highjacking someone elses sale and posting in the "For Sale Business Section". It's empty You could be the FIRST....................
Neil.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
