Heya Folks
Recently my front underspoiler came off from the front. Thats the one which sits underneath the stock GTR bar but just above the spoiler lip (I removed the lip cause the roads around here are craptastic). Its made of black plastic and it came off when I was reversing out of a carpark and it had gotten caught on some cement and ended up ripping a couple of bolt sections.
My mechanic can repair it, but I'm curious if there are any other aftermarket under body spoilers for both the front and the rear. I've seen some veilside cars that have the kit extending underneath the rear below the hicas and rear diff. I'd like to know if I can get any underbody spoilers for the entire car with stock kit (because I really hate that veilside stuff, not a fan of rice).
I have a custom exhaust from the cat back so I'm guessing some might not fit. The other alternative is if I find someone who custom makes them to fit (which I would probably prefer).
Have any of u guys/gals out there ever done any work to the under-body styling?
-D
https://www.sau.com.au/forums/topic/223578-underbody-spoilers/
Most road going cars cannot be lowered enough for these to start actually working anyway.
look at any race car that has diffusers and front underbody aero kits and they are extremely close to the ground, the idea is to speed tthe airflow under the car.
try it, but it will probably only be for looks.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
