  • Replies 53
Was heaps of fun.
Started off in a basketball court sized area with hay bales - then moved on to tyres. Then out in the bush with little bits of wood as cover.
Best one was the 'junkyard' with old cars and such. Then 'capture the flag' at a fort.
Doesn't hurt too much - just make sure it's not a very hot day. You get dehydrated easy.
https://www.sau.com.au/forums/topic/22358-paintball/#findComment-479296
I have been to the Moama and the coldstream one.. coldstream one is just past lilydale and nice and close. That one was better i thought because of the more curvatious terrain and plenty of trees which makes it more interesting.
I reckon the Moama one would make a more interesting day trip in terms of a good drive thrown in.. also allows some of the country boys up near the border to come along.
Speaking of which, we have one again in about two weeks through work :) still got the scars from the last one.. lol
So well my vote is we should do it - but as long as its not too close to 31st August
https://www.sau.com.au/forums/topic/22358-paintball/#findComment-479434
gordo... the people who own coldstream own the on out in Nallan.
i've been to both, the Ballan one is way better :)
https://www.sau.com.au/forums/topic/22358-paintball/#findComment-479467
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
