Item: haltech coilpacks x 6
Age: brand new
Condition: new
Price: $450
To Fit: (What car) any car
Contact: PM for details
Comments: these are the top of the range Haltech coil packs they are brand new and never been used, cars here in WA are running 8 seconds with these coilpacks and over 35psi boost without issues, great for any serious engine package.
Edited by unique1
https://www.sau.com.au/forums/topic/223638-haltech-coils-x-6/
Age: brand new
Condition: new
Price: $450
to suit what?
any pics
these are to suit any car, they have built in igniter, they are ls1 style coilpacks, i have made up a bracket to mount them under the rb26 coilpack cover as well. u will need short ign leads to run these under the cover though, once covers on u wont tell they are aftermarket. I have the parts for leads to make up custom ones as well if anyone wants to buy them as well.
heres a link to the ones they are... (top ones on that page)
http://www.haltech.com.au/igncoils.htm
hope it helps
how come you aren't using them in your 26/30 build?
are they any better than splitfires for the dicking around needed to fit them?
ps any luck with chasing down the CP's from the states,i have a set that i am using but you are welcome to have a look at them if it's any help,the spec sheet with them is very similar to the one in your post except the P.O Number is RB30/26 .827
cheers
paul
cheers
paul
Hey mate, my rb26/30 build is along way from being done, i gotta fund the build, hence the selling of bits and pieces i have lying around here.
I was planning on running them with a haltech e11v2 ecu and the tuner reccomended them for my current engine (600rwhp rb26) and said he has had no dramas with them on a 2jz running high 8s down the 1/4 mile and running 35psi+ boost levels. I changed tuners and never ever used the haltech at all or the coils and now the haltech is sold i have these coils here :)
The CP hunt is still on, im not chasing pistons right at the minute, im gonna attempt a stock bottom end and see what it can do first. I will keep on looking for the info but its not a huge priority at this stage. if i find anything out ill be posting info in the relevant thread.
are u from Perth? i can give u details of the workshop i bought them from and call them, they rave about them lol.
send me PM if u have any other questions mate
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
