  • Replies 74
  • 1 month later...
well it's been a while and the weather is warmin up so i think it's time to get this thread started again!!!
i'm thinking of a cruise in early october, open to suggestions. dunno if u guys want just a cruise or cruise and an event, eg go-carting, bowling, etc. (good go-cartin place in milperra/revesby called indy carts, 3 speed postie bike motor carts ;) )
anyone is welcome, i miss the old cruise an need one to satisfy my love for driving, lol.
Hiya!! :)
True time to get this thread moving again..Cruise, Karts could be interested ;)
So whats this you have gone to the dark side??
i'll be at oran this friday maybe, and there is a cruise to wollongong on the 4th. theres lots of stuff happening.. so i will likely break the car again lol so maybe carting is a good idea
Whats are Oran Friday?
Sif jinks yourself Jeff! :)
There are clutchless manual go carts in Revesby or the traditional type up in Minto.
Revesby: http://indykarts.com.au/
Minto: http://www.fastlanekarting.com.au/
MRXTCZ
Yeah been to Minto!!
Like that track, think its a goer just need a date???
11th or so?
jess friday is just an l2s practice day, but a few sauers are planning on being there. as far as i know all i will need is a fire extinguisher? willl find out soon enough i guess
11th sounds good to me :) Maybe have dinner at Black stump before we go karting?
Yeah thats all you need and your L2S licence :) The usual track day stuff
man i vote the revesby ones i've been twice an can't get enough. the track is a bit tight but u can kinda drift em on the last corner ;)
the only bad thing is there's no place close to have dinner, so if you guys want we can have dinner round c/town there drive out there let the food digest before we race :(
man i vote the revesby ones i've been twice an can't get enough. the track is a bit tight but u can kinda drift em on the last corner :merli:
the only bad thing is there's no place close to have dinner, so if you guys want we can have dinner round c/town there drive out there let the food digest before we race :laugh:
Sounds like a plan to me... :laugh: Do we need to book ?? Would rather just be able to rock up like Minto ones...
11th Oct cool with everyone???
Sounds like a plan to me... :D Do we need to book ?? Would rather just be able to rock up like Minto ones...
nah don't need to book i don't think many people know bout it...
11th is cool with me, so where we eatin an what time u wanna do it? carting closes at 9pm.
so maybe have dinner at bout 5-6, by the time we eat it will be bout 7 then cruise up to revesby an cart. i think at the carting they only do 6 at a time... so we'll need a bit of time there plus newbies get a lesson on how to drive em.
What is this place :D Newbies get driving lessons!!!!
Hmm thinking Minto sounds better cause can kart till late......I dont really feel like rushing all over the place..(just thinking out loud) :(
P.s Any of you guys going to the Dyno day at JEM on the 18th? I am so you should as well :(
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
