So not selling then? Lol
What else is done to it? Can Pm if you want. Looks mint either way. Needs wata's though
Good guess lol, It's not for sale at this stage. I seem to be asked that question quite a lot lately.
It's just got a totally standard L24 and factory 5 speed at the moment. No suspension mods, i took the springs out for AJD though.
Wata's do look good on them but without GTR flares you can't get decent dish. :mad:
  • 3 weeks later...
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
