Noticed that the "1/4 mile time honour roll' hasn't been updated in awhile so took it upon myself to create this list.
* This list is for Skyline models only.
* Please PM me your details to keep the thread clean:
- Car Model
- 60ft time
- TS
- 1/4 Time
- Tyre size (eg; 225/50/16)
- Tyre Pressure (eg; 36psi)
- Tyre Brand/model (eg; Nitto NT555R)
- Fuel Type used (eg; BP Ultimate, Optimax, etc)
* 1/4 Times are for 'you' and 'your' car only.
* Must be using PULP.
* Timeslips are required.
PLEASE NOTE:
Anyone that currently has incomplete information will be removed from the list in 1 weeks time. To have your missing information added please PM ME. I sent PM's to people with missing information a few months back and got about 5 replies so from now on you will only get added to this list if you have complete information.
The 1/4 Times are located at: http://skylines.pnc.com.au (click on the link located in the middle at the top). This URL can be bookmarked but dont bookmark the actual "times" list as that will change on every update.
PS. Read the instructions above, then re-read them again.
https://www.sau.com.au/forums/topic/22444-sau-14-times/
  • Replies 347
MODS at time of run 12.9
Apex Power FC (tuned by Martin Donnon)
Greddy FMIC
HKS Exhuast
Cat In Pipe
APEX filter
600hp Fuel pump
high flow fuel filter
HKS twin plate clutch
Cold air intake and partician
heat wrapped intercooler pipes
modified standard BOV( to hold over 13psi)
Slit dump pipe
HKS EVC IV
C's Quick shifter
Oil/air seperator
Octane booster (+2 degrees ignition)
Standard turbo
Mesh removed from Airflow meter
https://www.sau.com.au/forums/topic/22444-sau-14-times/#findComment-482946
Guest INASNT
Greddy FMIC
HKS Exhuast
Cat In Pipe
APEX filter
600hp Fuel pump
Slit dump pipe
HKS EVC IV
C's Quick shifter
Oil/air seperator
Standard turbo
Was that with 245rwkw or 225rwkw??
https://www.sau.com.au/forums/topic/22444-sau-14-times/#findComment-483329
I got a 13.981 at 95.3 mph in my R33 GTS-T.. here is the timeslip i posted on here a while back: http://www.skylinesaustralia.com/forums/at...=&postid=259667
Been a while since i've been down the 1/4.. probably time to give it another run actually. With my new fuel pump hopefully can be get around 13.7.
https://www.sau.com.au/forums/topic/22444-sau-14-times/#findComment-484782
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
