  • Replies 347
Well I am new to this site and I'm just passing by to say hi... This site rocks and so does my car....
Take care everybody :D ....Elle :)
hey Elle just a quick hello from the gold coast, have you done much work to your ride? and if so how quick? mine is still standard except 4 some bolt ons, but still damn fast 4 a street car. :headspin:
Tonight at WSID I beat my PB (14.46sec) and was relatively happy with the outcome. I did 4 pretty consistent runs but all feeling totally different behind the wheel. I had 2 goals at the beginning of the nite and didn't care which I got first. My 2 goals were 13.9sec ET or better and 100mph or better.
1) Didn't do much/any of a burnout just dropped it from 4,000rpm and let it spin for a metre to remove the water from the rear tyres. Used standard boost (7psi) and launched from 3000rpm. The entire 14.184sec felt like a Sunday drive, everything was perfectly smooth no wheelspin just perfect.
60ft: 2.168 (~3,000rpm)
MPH: 99.94
ET: 14.184sec
2) This time I switched it to 12psi to try and get abit more top end but resulted in axle tramp in the top of 1st gear and problems engaging 2nd gear.
60ft: 2.117 (~3,500rpm)
MPH: 98.66
ET: 14.383
3) Thought i'd use 7psi for first gear and then flick it to 12psi soon as I hit 2nd gear. Got my highest Mph but lost out from 1000ft -> 1320ft somehow even though I had a higher TS.
60ft: 2.098 (~4,000rpm)
MPH: 100.52
ET: 14.245
4) Bahh what a waste, too busy concentrating on the v8 beside me pulling away and I had a combination of axle tramp and missing 3rd gear.
60ft: 2.111 (~3,000rpm)
MPH: 94.70
ET: 14.702
Mods:
FMIC
K&N Panel Filter
3" Full exhaust
Bosch Fuel Pump
Daiken Clutch
7/12psi
I'm very happy with my 60ft times (Using 10,000km old 225/50/16 @ 38psi Michelin Preceda's). They were very consistent with no wheelspin at all. I need to tweak the rear suspension so i'll take a look at that this weekend and probably drop to ~20psi for next time just to try and get those 60ft times lower again.
Ben,
You can add my latest numbers to the list if you'd like. Cheers bud :D
ET - 12.870
MPH - 117.75
60ft - 2.476
ET - 12.847
MPH - 115.65
60 - 2.353
TYRES - RE540S
TRACTION - NONE!
NITTOS - NEED SOME :D
Nope.
Let the sh1tty crappy 99% dead tyres down to 11psi and fried 'em till they melted onto the tar... SLipped the clutch till it bit and it bit hard so i mashed the throttle and got all the way off the clutch... pics to come :)
Adrian
Hi every1
Im new here and hope to catch up with you all soon.
I've met Ben and Adrian at the last Street meet had a ball and ran a not bad time for my first time out.. (congrats on the 12.5 Adrian)
Ben can you add me to the list when ya ready mate
ET - 13.980
TS - 100.76
60ft 2.157
Bridgestone GRID II 255-40-17 @ 20PSI
BP 98 octane
you have the time slip on this one Ben :)
not fair, does it have to be on pulp, ill run it this week on optimax
LIES.
hey adrian got my new clutch, and it grips like a mother ***cer, ill be there on wednesday after i get some more fuel,wasted it all drivingto the wrkshop, hope to get another run next to you, and some more pics. i also think i should drop the pressure in my tires to about 11psi, 25 is way to much what i used last time.
Motion not to add nicknick's time until someone from SAU watches his fill up at the Shell at Eastern Creek before the drags :rofl: :rofl: :rofl:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
