Hi guys sorry if its already been asked but i really dont want to read 20+ pages!
My engine is getting tuned in a few weeks(rb25 conversion into a 32) and im using the standard rb20box for the moment. Im looking at changing gearbox oils as my clutch is getting installed later in the week so i thought now is a good a time as any. Its currently abit notchy from 3rd to 4th but i dont get any crunching in high gears etc. Ive read redline can be bad if your gearbox isnt on its way (ie bad syncros) but i dont really know if a 'notchy' gearbox is considered on its way :wave:. Im basically looking at any ways to give my box a easier life. Any info on the matter would be appreciated.
Cheers!
My engine is getting tuned in a few weeks(rb25 conversion into a 32) and im using the standard rb20box for the moment. Im looking at changing gearbox oils as my clutch is getting installed later in the week so i thought now is a good a time as any. Its currently abit notchy from 3rd to 4th but i dont get any crunching in high gears etc. Ive read redline can be bad if your gearbox isnt on its way (ie bad syncros) but i dont really know if a 'notchy' gearbox is considered on its way :laugh:. Im basically looking at any ways to give my box a easier life. Any info on the matter would be appreciated.
Cheers!
Go for the Redline MT90 75w90 gear oil instead of the light weight shockproof. It will improved your notchy shifting.
Hey mate
German Castrol...where can I get some you reckon?
I did my first UOA on my Redline in my FTO...not stella results but as expected as its the first run with the redline. I use the 5W30. I will do an oil chnage and run it again for 5k and sample it again. Si levels were a bit high....go to BITOG and have a look a thte results if u like..
I will get another kit and test the R33 which has been running 10W40 Redline for about 7000kms...I'm thinking of switching to the 5W30 in the R33 also...or even the GC if I could get it in both...depending on the price.
But I think I will do some runs with both with the redline and see if after about 3 OCIs I can get some good results.
KJ
KJ
Did you send in a VOA?
Si generally indicates poor air filtration.
What else made you think it was a poor uoa apart from the high levels of silicon?
Hey mate
KJ
Can be found in Ebay.
Castrol Syntec 0w30
Si and all metals in my UOA are pretty high comparatively. Redline will give higher wear numbers at first due to cleaning values. So its only the first and hard to tell. But if u looked at it at a glance, it would be no great. I'm doing more soon on the line and and sample in the FTO.
Castrol Syntec 0w30
thanks..
I have been ordering from Harold @ (0414369 926) Performancelub.com. Might be the same guy as the products are the same and the price is also...I didn't realise he sold Castrol.. !
I have decided to stick with reldine for the moment, do some more tests and see what happens.
thanks..
I have seen your UOA and doubt you will have an accurate reading unless after 3 OCI, ester base Redline has an aggressive cleaning abilities and it will show higher wear reading from the metal it displace. I would say save your UOA test till at less 30k later.
I was going to do another one just cos I'm intrested to see if the numbers come out similar.
Apart form that I've got a new batch of the 5W30 from Harold above and putting that in soon.
Next is the r33. I have been using 10W40 redline but I have noticed a bit of oil usage, not to much. SO I asked the boys if they reckon a 30wt would help say seal the rings a bit better. So I'm giving that a go also...
Hey guys just looking at doing an oil change for my R34 GTT. I bought some Motul 300v 5W30 is that going to be okay? At the moment the max temps down here are around the high 20s/low 30s but avgs around mid 20s. The car currently has elf 10w/50 in it.
Also is 4L enough or do I need to go buy another 2L container? (was the only size they had)
5w30 is good but do check your AFR if it's running rich or lean as too rich a AFR will increase fuel dilution in the oil thus making it thinner than 30wt.
Hey thanks mate, I actually read around a bit and ended up taking 300v back and getting 5L of the Motul turbolite 10w40. Was a lot cheaper than the 4L of 300v and as you mentioned I didn't want to run the risk of it getting 'too' thin.
Anyway all went well and the car feels so much nicer to drive :P
Anyway all went well and the car feels so much nicer to drive :no:
Motul turbolite 10w40 is just a Semi-Syn oil, I would recommend at least a fully synthetic for turbo cleanliness and high temp protection. A wide spread 10w40 type semi-syn is not really a good idea for ring cleanliness i would think. Choose Mobil 0w40 or Delvac 5w40, whichever is cheaper. those are good oil at reasonable prices.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
