Its more the point of why buy a crap so called 'synthetic' grpIII oil when for the same price u can get another brand that is based on the 'better' grpiv.
I run the Motul 5w40 for $59.
Beats the crap out of the Castrol 5w30 and Shell 5w40 of which are grp3 based and strangely my motor appears to use a little oil each change at 5k. The Motul 5w40 or Mobil 5w50 it doesn't use a drop. Interestingly they are both grpiv oils.
The fact that he/she is changing at 5K intervals does negate part of the problem, assuming he doesn't change his oil filter every 5K with it, but there are better oils out there.
However, I just disagree with the "ask your local autobarn for there recommendation" when we have a huge discussion and a summary of the oils in the first post.
There's been plenty of effort to guide people on what oils to buy, I'm not an expert but at least I've researched my opinion.
I run 98 octane fuel only in my Skyline, its what its tuned for.
I just dont see any concrete evidence about which oil is better than another apart from these used oil tests (no I cbf sifting through 48 pages to look for them either), fyi I did read this thread and some of the associated links before I selected the oil I was going to use, even Mobil 1 oil is around 80 bucks a bottle for 0w/40, and I use more than 5 litres of oil in a service (due to the bigger sump).
Not all salespeople are clueless morons either. I know of 2 guys who work at different parts franchise shops here who are Skyline owners and very knowledgeable.
The main reasons I ended up going with the Castrol were the fact that several mates use it in their Skylines which do get driven hard regularly and over a long period, and my parents have always used it in their RB30 Patrol which has just gone over 400 000km and still running fine, which suggests to me that it cant be as bad as some of you are making out.
The one and only time I've seen oil make a performance difference was when a local performance mechanic gave me a demonstration of an LS1 running Pennzoil 5w30 on a dyno, which then had the oil immediately changed to Martini 0w40 IIRC for a 3rwkw gain. Therefore if I were to try anything else it would be that first.
Btw, what is wrong with changing the oil filter at 5000km?
Technically, for 5W30, Motul X-max(5W30) has a closer viscosity than X-cess(5W40). There are also Mobil1 5W30 silver bottle silver cap that I have seen around. So there are heaps of choices. Not just Castrol....
I see no advantage in using higher quality based stock oil if a person is doing 3 summer months, 5000km OCI driving in grandma style....
So there is no good or bad oil, just depends on your application, OCI, driving style, weather conditions....
The average skyline isn't driven grandma style. The grpiii based oils I have tried all have been consumed slightly by the motor. The grpiv oils however not a drop.
I am just exaggerating, I am sure you understand what I am trying to say.
In terms of oil consumption, that's a perfect example. If you find out that with the conditions of your engine and your driving style, Edge Sport did seem to be burnt off more than X-cess. That X-cess is perfect for you.
P.S. personally, I think oil consumption have more to do with viscosity VS oil pressure and add packs than based stock oil.
I can agree with cubes, in my mildly tuned r34 the motul xcess 8100 5-40 has really improved the way the car runs.. It doesnt burn almost any oil, in my last 3 changes. However i have seen a drop of oil leak say every week.. Wondering if a move to a 10w-40 would help the slight leak..
However all in all the xcess 8100 has really tested itself- i find it stays golden till about 4000kms and then starts to slowly go darker so by 5000km it looks dark. Great oil for the money :D
i'm going to try the martini oil then the motul just to satisfy myself to see if there is any difference compared to the castrol.
Now can anyone shed any light on whether Redline Shockproof Lightweight is really any good for going into a Stagea manual box with a noisy 4th syncro, or am I better off just getting any synthetic 80w90?
...doesnt burn almost any oil, in my last 3 changes. However i have seen a drop of oil leak say every week.. Wondering if a move to a 10w-40 would help the slight leak..
If it is just a drop every week, I would not worry about it. You could try to trace it so you know exactly where it is leaking from. Probably just some bolts and nuts not tight enough.
The RB30 is a forklift motor so that probably explains a bit. :blink:
I did not split the oil filter open with the castrol 5w30 but with the shell 5w40 i found little lumps of what looked like grease.
I then ran Motul.. no sludge in the filter.
I switched between oils a few times. Everytime the shell stuff deposited sludgy lumps in to the filter.
Maybe thats where the 5w40 Shell was burning/sludging off too :D
There is sludge and vanish build up in the valvetrain area and then there is sludge like material clogging the oil filter. I believe they are different, just think about the temperature different between these two areas.....
Then there should not be a relation between burning (oil consumption) and sludging..
Burning will likely leave carbon deposit in and around components of the chamber...
Sludging are more due to high heat and baked-dry up oil....
Don't know may be someone who have more experience can chip in.....
Definitely. I was a little misleading stating consumed when in fact it was being caught in the filter as slight sludge.
The motor has been rebuilt, always had regular oil changes. I can't comment on the bottom end but the top end and cam covers are super clean inside.
Hey guys new to SAU and have just brought a 93 r32 gtst with 121xxx km's which is stock standard.
Im wanting to do oil changes for engine, gearbox and diff. After reading the post think i've decided on motul 300v but still not 100% sure for the engine but have no idea on gearbox or diff oils? also how much oil does engine, gearbox and diff hold? Prices and avalibilty isn't a problem as i work at the local repco store but would rather take advise from you guys/girls because repco only know holden/ford best lol.
thanks.
^ rb25 takles around 3.7-3.8 L of engine oil.
diff is around 2L
and gearbox is around 2.2L
does anyone know whats a good & recommended fully synthetic oil for a neo rb25de ?
cheers
my 34 takes 5 and a bit litres of engine oil, not sure where you're getting 3.7 from?? :rofl:
does anyone know whats a good & recommended fully synthetic oil for a neo rb25de ? have you read anything in here??
my rb26 has over a 100k on the dail whats a recomended oil, sumthin with a lil more thickness to it???
No, as per previous discussion in the thread you do not need to buy thicker oil as the engine gets older.
apprently 10w-40/15w-40 is recommended for RB's?
narrowing it down to these 2..
Penrite Sin oil 15 15w-40
elf competition GT 10w-40
currently using mobil 1 syn-s 10w-40 and afaik isn't available anymore & has been replaced with another name, mobil 2000 or something.
gonna change to fully synthetic to either one of the above mentioned ones.
car is due for a change in a months time so see how it goes then.
ive read that with the full synthetic oils, they still stay the gold colour after 4000km.
with the current oil im using, it starts to change colour after 2500~km, im guessing the oil im using isn't that good?
any opinions with the 2 oils ive chosen ?
wheres the cheapeast place in syd to get either of the 2?
cheers
Edited by dori32
hey guys....what would be the best oil for a noisy rb manual gear box.. i know ive ogtta get it rebuilt soon.... but gotta hold off until i have the coin... is there any oils ( i think thicker is better ) to quiet it down a lil?? cheers
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
