Hey guys; I've been looking around for an autech kit or dolphin kit for my silver S2.
Reason being - obviously look hot - and I think its better not to chop up my DAYZ kit for my FMIC.
I'd either buy the kit outright, or trade for my DAYZ kit (silver) + cash.
I'd definitely prefare silver over anything else.
Ps: Is the only difference between S1 and S2 autech kits the grille?
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/
Thanks Mike =)
I've already got the dolphin grille, but I'm just wondering for the front bar + rear bar + side skirts if there's any size difference. Reason being when you take the kit off, from my eyes it looks essentially the same as the S1.
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-3961429
Thanks Mike =)
id almost put money on sides and rear being the same but the bar is deff different due to the position of the posts either side of the grill the actual grill is larger on the s2
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-3962114
  • 4 weeks later...
Hold out for a while i may be brokering a deal to get mine repaired and moulds taken off it once the deal is finalised i'll be posting up a expression of interest thread in the stagea section oh it's a 260rs front bar with masa sideskirts and rear bar.
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-4016329
Hi Andy, have you had any more word on this? My front lip from my Autech kit is pretty much smashed going to cost me bout $500 to get it fixed and painted and would much rather a new one...
Cheers
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-4042774
Cheers andy, im really just after the lower lip of the 206RS. As having it aslow as mine is it cops a bit of a battering and somone decided to put the car on a towy without taking it off which left a great hole on one side. not sure as to whether i should get it fixed or just buy a newy.
Will keep checking back though.
Cheers
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-4057903
  • 4 weeks later...
Yep no worries just keep me posted if you decide to do something with it. I have been looking for just the lower lip for months unsuccesfully so will more than likely just buy the whole front... As buying the lip from Nissan Japan is way too expensive for it to be feasable. I have had quotes to get it fixed but i'd like to do a propper replacement job.
https://www.sau.com.au/forums/topic/224628-wtb-autech-kit/#findComment-4130213
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
