Hi Mark,
Welcome to SAU - Your ride sounds sweet - I've not seen too many Red R34 GT-Ts - They are all yellow, blue, white or black hey ??
Anyways, Enjoy SAU and don't be a stranger - Come down to a track day or cruze or two. !!
Cheers,
https://www.sau.com.au/forums/topic/22471-hi-im-a-newbie/#findComment-482273
heaps of silver ones around too B-man!
welcome to the site Mark, your car sounds v.sexy...put up a pic if you've got one! :)
https://www.sau.com.au/forums/topic/22471-hi-im-a-newbie/#findComment-484629
Im a newb my name is Daniel, I just bought a 1985 skyline its a r30 from what ive been reading and has no turbo :D. Im 18 and live in Orange. I dunno much about cars and any help would be cool.
I have been reading past posts and suff and the model I have is old, but hey it only costs me $1000. Any information how I can do some little mods or just plain nformation on my car or skylines, would be welcome.
Ill properly ask questions as they arise as knw nothing :|.
Oh well I may aswell start now, why doesnt it go? I changed the leads the plugs the distbutor cap, it will turn over but wont start, i can smell the petrol but it just wont kick any ideas?
P.S I hope to post a pic soon of my stocky skyline.
https://www.sau.com.au/forums/topic/22471-hi-im-a-newbie/#findComment-498278
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
