BBL - Steven
I managed to get about 35 laps as passenger in it giving some directions. His first time on the track, 383awkw on 17psi with a T88 with a very expensive bottom end. Was quite laggy but hammered down the front and back straights once over 5000rpm especially with that screamer pipe.
haha that car made me laugh every time it came on boost too. I don't know why people complain about t88 being laggy if thats what they feel like, I was able to keep it on boost ok only using 4k-6k let alone all the way to 8 or whatever it goes to. very nice car just needs some sway bars and semis to get to 1.06-1.07.
wow its a wicked looking car sounds like it goes well too
i thought i was over R32s......now im thinking im not! Damn decisions ha ha
  • Replies 135
It had a miss between 2-3000rpm so trying to get it to move when releasing the clutch was an issue as duncan found out a couple of times.
So apart from John in the boat who had the quickest time?
Don't know cause not everyone was timed...
I reckon me and Jay would of done pretty good times like low 1:11's
Sounds about right.. Dave was doing low 1:11's in mine... only time he seem to catch you was when you spun out one session I think???
Hi Andrew.... I'm interested in any pics you may have of my car. It was the red R33 GTS-T (Series 2) with the R33 GTR wheels. How much is the CD?
Hiya...
There's a very good chance that I'll have some nice shots of your car. But I'll need a description that singles your car out a little more. Eg: Number plates.
The cost is $20 for a cd with high resolution images. If you can give me some more details of your car, I'll see what I can do about posting a shot.
-Andrew
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
