This is a r33 turbo manual that has had mainly rear damage and front right guard,it still drives perfectly and is mechanically perfect,recently had the engine completely rebuilt.the car has an arc aluminium radiator and arc intercooler,hks 2535 turbo,enkei mag wheels,turbo timer turbo boost guage,aftermarket temp guage into top hose,rev speed meter apexi,gtr driver seat,3 inch exhaust,pod filtre,mines computer,strut in engine bay and through middle of car,japanese car cd/tuner,front and rear fibreglass spoilers damaged but can be repaired ,side panels also one damaged,would prob need a rear drivers quarter panel to fix,a front drivers bolt on guard,and the rear left needs panel beating.none of the frame is damaged at front mainly the fibreglass spoiler that makes it look worse than it is.no damage to bonnet or roofall glass perfect also
https://www.sau.com.au/forums/topic/225037-damaged-r33-95-mechanically-perfect/
thinking of selling complete first been offered $8000 but if i cant confirm that will strip it down and sell all the bits individually soon as all mechanicals are good only done 110k
what sort of suspension does it have?
its got aftermarket h/duty suspension all round ill check its name tomorow think it began with p and theres an adjusting spanner for them all
if you are separating, pm me a price for the turbo
i dont know what fair s/h prices for all these things are yet sorry will have to do some research,any expressions of interest for things would be appreciated and what you also think is a fair price would be good and the engine is running perfect i guess it pays to sell that first so a buyer can see it is running perfectly before all the bits around it are removed ,and the last post i meant passenger guard is good drivers side not
pm sent
im interested in the suspension! And about $500 ish is typical depending on type and condition!
think its called quantum coilovers im still trying to read the info on them they are not standard will look sunday again
$1200 for the rims depending on the condition of the rubber.. price on the arc radiater??
the rims are all in good condition enkei 17 inch ,rubber is down i cant really tell as im stipping it for my son think it looks about 25 % to me but could be more as im not sure how deep they are new on these tyres.how much are you offering for the lot including radiator its a 36mm type arc radiator
Which group of gypsies you hit ?
lol haha
good luck with the sale mate
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
