On my 33 GTS25t I've got a set of White Enkei's in 17x9JJ38 (Rear) and 17x8JJ38 (Front) and they fill almost perfectly! My car is pretty low though too.
I think to fill it just a little better, I'd go half a size up on both the front and the rear, but I think the back would probably need flaring if that was the case. :D
I think to fill it just a little better, I'd go half a size up on both the front and the rear, but I think the back would probably need flaring if that was the case. :)
Nice Rims, Thanks for the suggestion.
Looks like not many people have wide wheels on their R33's
17x8 and 17x9 (gtr offset and size) fit your R33 perfectly
but wouldnt those sizes be illegal? on the RTA website it says you can go 1" wider and 2" bigger from stock. So the R33 GTST wheels are stock 16x6.5? meaning legally you can only go 18x7.5?
I think the wheel restictions for S.A. are that the diameter cant be greater than 15mm from the largest tyresize listed on the tyre placard and that the offset of the rim does not vary by more than 13mm from the original rim.
You want the "JDM look" but you don't want to flare the guards? To fit some decent wheels you'll need to flare the rears at least a little.
Don't be weak, if your going 17" go 17x9" +17 front and rear. Will fit with ease with stretched tyres and rolled gaurds and a light flare on the rear.
dude if u want the jdm style get 18's but if ya bit tight go with 17's!
in my opinon 18's are the best size for most imports they just suit the car more! you just dont wanna go over board with some 20's!
remember guys it's just my opinon lol
  • 4 months later...
93 r33 GTS-T i have some enkies 18x9JJ +22 Offset got some 225 in front and 245 rear. Perfect fitement and look but the rear have a few fender scuffs on the rubber !
im looking to sell those rims and got with Rota p45R, either 17x9 +30 or 18x9 +20 any one using this setup ?!
Im looking to find out what is the JJ stand for ?!?
Mate, what suspension setup do you have? That is EXACTLY the ride height I want to have on my 33. Does that clear the legal height limits? Looks fantastic. Well done.
define "jdm" look.
i was running -6 rear and -4 front 17x9 with 215 tires for awhile. got sick of pizza cutter tires, now im +10 17x9 with a 255 tire, all 4 fenders rolled.
youre not going to get the "jdm" look without rolling your fenders. people here do it for 40 bucks a fender with the rolling tool and a heat gun
Hey guys,
I found this googeling around and you can compare the stats of the new wheels you want to put on with the ones you have atm and it tells you how many mm of clearance is taken or given
http://www.1010tires.com/WheelOffsetCalculator.asp
Enjoy !
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
