Hey guys,
Just trying to get the word out to all the clubs. Last year was a reasonable success, although it was held on the same day as another large Adelaide event. The turn out was pretty good last year, but this year we want to make it huge! We had and do have a number of sponsors for the event, and hence prizes & awards on the day.
Link to official webpage is below:
http://www.dynoday.info/
Hope to see some of you guys attending or entering..
Rick.
  • Replies 137
Posted Images
^^ beter not enter then there were a few high KW pulsars last year :)
i may enter again good to get another reading on a AWD dyno see if i can get the PFC in by then
i scored 16th last year
>>Results<<
May enter this.. see what my car comes back with in kws today
I went last year, was good. And well run. We cruised down as a group to from ingle farm carpark
Edited by Adz2332
Wow! What a response from you guys, which is awesome to see.. :)
Damo - It is a competition with prizes, etc.. but feel free to enter just to get a number for your own piece of mind. I know of a quite a few that did so last year, just for that reason. Myself being one.
Please by all means enter, it was great to hear some RB burble on the dyno last year.
Rick.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
