hey there,
i have the oppertunity to offer members HID kits at a low price, these kits a plug and play kits and include all the brackets and fittings for fitment.
these are available i a wide colour range - 4300k,5000k,6000k,8000k,10000k,12000k
Picture of the standard Kit:
Picture of the Hi/Lo kit:
Name List:
Bank Details
ANZ
Acc Name. Dion Coulls
BSB . 012551
Acc No. 483047064
Prices.
I will put in a cut off date/time for this group buy so that people will not be waiting for numbers to be filled, once the numbers are sufficient.
But i invite anyone to ask there mates if they are interested in buying also.
PLEASE SPECIFY WHICH BULB TYPE AND TEMPERATURE RATING YOU NEED IN YOUR POST or PM.
If there is 10 or more buyers
1x HID Kit To suit H1/H3/H4(single, Please add $15 for Hi/Lo option)/H7/H11/HB3/HB4/9007
Including Postage ANYWHERE in Australia
$ 170.
25 or more
$ 160.
and if it reaches 50 sets or more
$ 155.
I can supply White T10 Wedge parkers for aditional $10 / pair
If there are any issues with the kits I will do my best to replace parts under warranty just the shipping to and forth can take up considerable time if there is any failure to the parts.
If you have any questions or quieries dont hesitate to ask
https://www.sau.com.au/forums/topic/225507-hid-kit-group-buy/
  • Replies 129
i have this same Kit from a group buy on the R31skylineclub Angry ran that group buy im sure youve got the same contact,
any ways top kit looks great :) if that helps anyone decide out the quality
Yeah i seen his group buy there but i didnt want to cut his grass, mine are cheaper to :cool:
and Whyallapunk, im not to sure i think it depends on the year of your R32 to which globes you have
i dont know that there any good for parkers i have a bunch of those already maybe i should try one out
why i say there no good id LED isnt multi directional beam i have these in atm but want something brighter
but want something like this
Min maybe we can combine shipping and when we catch up next i can give your your globes
go out and pop your bonnet on top of your lights should tell you what type that are and there wattage
ah good point i don't want another kit for my high beams so i can run a relay and have 4x HID power muhahahahaa but yeah that wont be too soon as doing a clutch and install then other things first
Guest
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
