hey there,
i have the oppertunity to offer members HID kits at a low price, these kits a plug and play kits and include all the brackets and fittings for fitment.
these are available i a wide colour range - 4300k,5000k,6000k,8000k,10000k,12000k
Picture of the standard Kit:
Picture of the Hi/Lo kit:
Name List:
Bank Details
ANZ
Acc Name. Dion Coulls
BSB . 012551
Acc No. 483047064
Prices.
I will put in a cut off date/time for this group buy so that people will not be waiting for numbers to be filled, once the numbers are sufficient.
But i invite anyone to ask there mates if they are interested in buying also.
PLEASE SPECIFY WHICH BULB TYPE AND TEMPERATURE RATING YOU NEED IN YOUR POST or PM.
If there is 10 or more buyers
1x HID Kit To suit H1/H3/H4(single, Please add $15 for Hi/Lo option)/H7/H11/HB3/HB4/9007
Including Postage ANYWHERE in Australia
$ 170.
25 or more
$ 160.
and if it reaches 50 sets or more
$ 155.
I can supply White T10 Wedge parkers for aditional $10 / pair
If there are any issues with the kits I will do my best to replace parts under warranty just the shipping to and forth can take up considerable time if there is any failure to the parts.
If you have any questions or quieries dont hesitate to ask
https://www.sau.com.au/forums/topic/225507-hid-kit-group-buy/
  • Replies 129
i have this same Kit from a group buy on the R31skylineclub Angry ran that group buy im sure youve got the same contact,
any ways top kit looks great :) if that helps anyone decide out the quality
Yeah i seen his group buy there but i didnt want to cut his grass, mine are cheaper to :cool:
and Whyallapunk, im not to sure i think it depends on the year of your R32 to which globes you have
i dont know that there any good for parkers i have a bunch of those already maybe i should try one out
why i say there no good id LED isnt multi directional beam i have these in atm but want something brighter
but want something like this
Min maybe we can combine shipping and when we catch up next i can give your your globes
go out and pop your bonnet on top of your lights should tell you what type that are and there wattage
ah good point i don't want another kit for my high beams so i can run a relay and have 4x HID power muhahahahaa but yeah that wont be too soon as doing a clutch and install then other things first
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
