Ok im kinda noob, if i get get the option of hi/low does that mean its a highbeam and lowbeam in one? And if i have it on highbeam would i have my other highbeam on aswell
=/? im so confused... sorry about the noob question but i know nothing about HID's...
  • Replies 129
its all good, the hi/lo globe means that it has a highbeam and lowbeam globe in one, very similar to you standard H4 globe, when you turn your car over to highbeam both globes (standard highbeam and your hi/lo HID light) will be on
Im interested in a single kit for the R33 gts-t in 10000k or 12000k. Also is the Hi/Lo option a waste on the r33 considering high beams are on a different globe?
Also would be in for the parkers above for the $15 a pair.
the hi/lo option would be if the same globe isnt on when you turn your high beam on
The list, i think the easyer way to do this since i cant edit the first post would be to copy the list and add your name to it and your order(remember to specify what globe type and the K rating)
Whyallapunk - awaiting globe conformation
DRF72 - H4 HI/LO + parkers waiting on K rating
Min_R32 - awaiting globe conformation + parkers
Madaz - parkers
krzysis - awaiting globe conformation + parkers 10000k
Nismo_God -
you dont search too hard
H3 Suit Nissan S13 Silvia /R32 Skyline
Gahhh can anyone tell me what kind of type i need for my R32 GTST!? But yeah i'd take the hi/low option plus those parkers :)
it would depend on the year model actually.
could be h3 or h1 from what i've found.
can someone confirm as well for me? ive got a '94 32 gtr vspec II. prety sure its H1, but im guessing you dont talk back if i order the wrong one lol.
thanks.
hanyou - as stated twice ealier once by me and once by wkd-031 it should be stamped on top of your lights pop your hood and take a look
oh sorry i forgot to mention my car is in customs still lol so thats why i was unsure ;)
thanks WKD-031 that helps heaps!
will send a pm shortly
i pulled the globes out of my headlights last night, they are phillips crystal vision ones and on the back it has stamped H1
i drive a gts-t so make sure you check!
also im interested in a set :D
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
