hi guys i got my fuel pump and pressure reg delivered today. something else came in the box which im not quite sure about. it came in a genuine nissan box and has "A VALVE CUT" on it. i am yet to pull my pump out so im not sure where it goes or what it does. it is in the picture on the bottom right.
https://www.sau.com.au/forums/topic/225807-fuel-pump/
Not positive but could be the fuel valve (in red on pic) , fits on the pump outlet hose inside the tank, you should see it when you pull your old on out. What did you buy and from where ? looks like a Skyline pump assembly.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976856
http://www.skylinesaustralia.com/forums/Fu...mp;hl=fuel+pump
completely different, although basic pump may be the same, which is all you needed, wiring is also diffferent. may be a challenge.
I ended up getting a SARD universal, direct drop-in replacement for the Stagea pump
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976897
well positive and negative is all the same regardless with wiring so that wont be hard to overcome shoudln't be to hard to get the pump into the stag bracket. so with any luck i will make it work. cant complain for $300 all up.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976905
hey chook, i to have the sard fuel pump but i had some problems with its dual flow rates..the idol flow rate makes the stag have a flat spot on takking off from a standing start.. did u have this problem? the auto spark is going to earth the pump so it runs at 100 percent all the time
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3977243
  • 4 months later...
Hi guys, anyone installed a Walbro GSS342? It's 255LPH/500hp pretty similar spec's to bosch 040, and is also an in-tank pump... workshop recommended them over the Bosch; apparently the feedback they have had is that they are quieter than the 040 and very easy to fit. Just wondering if anyone's fitted one themselves to a series 2 stagea? How easy is it?
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-4249291
  • 9 months later...
Sorry for waking up an old thread, but if you're fitting a 040 pump how much do you fuel-proof the wiring to the pump? Are the rubber boots enough. I notice the stock pump has the plugs, but no real protection against the fuel.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-4764652
  • 4 months later...
Did you find out anything in the end Ruby? I just got a 040 replacement for my 12-month-old Walbro (which died :rant:) and could do with some advice on how to get it into the bracket - it's frickin huge compared to the GSS-342 Walbro!
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5000237
there is a photo on here somewhere of a 040 mounted on a stagea bracket . yeah its big but it fits well. i am not a fan of wallbros really . if something is smaller then it is doing more work and going to wear faster than something twice the size doing the same amount of work . and it would be twice as hard to make to the same standard so it should cost twice as much but it doesnt so yeah .
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5003132
Hey that's interesting, thanks Lachlan. Didn't find that one! Just what I was after.
However ditching the cradle completely like that means no direct supply of fuel to the pump when the inch or two that's left in the bottom of the tank runs away during a corner... and I thought that pump had been designed to mount vertically? The pickup covers the whole end; so as the fuel level begins to drop a lot of it will become exposed...
Sold my 040 now but having a fuel pump die on you is still a little concerning... had a bit of a hassle starting it again tonight, after only about its 3rd real run since changing the pump. Not sure if it was still bleeding air out or I had bad fuel or what.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5003885
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
