Hey,
After attempting to fit a new case on the Nokia N70, it looks great but the power switch fell out, it just sort of sits there under the case, and when I put it back in it just didn't work again.
I can press the button as much as a like, sometimes it works if its in the correct position, but then it falls out of there again, the only consistent way is with the case off touch the front of the switch with a piece of metal and it works fine (like the tool to remove the case).
Obviously that's not a solution for powering the phone on / off.
I've spent a few hours on it and searched the net, but does anyone know a good phone repairer?
Anyone?
I would look around near work (Burnley area) but I'm looking to not get ripped off (too badly :laugh:).
Regards,
Gareth
https://www.sau.com.au/forums/topic/226201-mobile-phone-repairer/
A lot of those mobile repair dudes you see in shopping centres will make a snack of that. I had a similar problem with my N70..for some reason the on/off button stopped working. I always had it on so it didnt bother me.But when i flew to QLD and had to switch it off when boarding. ( battery out ) Well the phone was useless up their. Took it to one of those phone repair dudes. He replaced the switch in under half an hour for less than $75 ...I was happy...never had problems since
I assume you mean the surface mount swith? It's come off the board yeah? I've fixed about 3-4 of them now including my current phone, Nokia's are piss poor when it comes to this. I could fix it provided the board isn't damaged :miner:
Kinds looks like this but a little different -
Looks quite different to me, here are the dismantling instructions:
http://www.uselessinfo.pwp.blueyonder.co.uk/dismantlen70.htm
But they don't actually show the power button, just it been removed with tweesers.
Its a little square thing with a button and two wires each side:
With a minute button on top that can be pressed with something extremely tiny, its probably less than 1cm across and 1cm down.
I'll have to find a shopping center, or one of those random 'we repair mobile phones' signs and call them on the weekend. Just need to track them down.
Mate, if you're in the Burnley area then head to Church St, where maccas is. Next to it there is a B shop, he is a repairer there, ask for Ken. Will look after you...
Another place to try for cheap repair is Victoria st, there's like 10000 mobile phone shops there.
Evan.
Evan.
Hey,
I'm in Burnley near the Yarra, I'll look for this place on Church street then. Thanks.
Not quite sure where the Maccas on Church street is though....EDIT: seems to be a bit past Bridge road heading towards Victoria street.
Oh and was that a "3" shop rather than a "B" shop? What's a B shop?
Yeah that's the switch I'm talking about, just couldn't find a pic of one, anyhoo yeah I can fix but all good :D
Ah damn, I could have waited and probably saved a few $$$, I dropped off the phone and was told to come back in 40mins-1hour and it cost $65 to get a new switch in.
All good now, last time I ever remove the top of the case lol.
Thanks anyway.
Where did you get it repaired in the end?
Sorry, it was by "Chang" at the B shop next to McDonald's, it did take a while to get there and back but I'm just glad its fixed, it was driving me insane having a brand new phone I couldn't turn on and off :P
Thanks
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
