Hey forum how is everyone doing? I am looking at upgrading my turbo and I am not to picky about horsepower and all tht, just want a good upgrade. Now my question is, Which garrett turbo can I use with the turbine exhaust of my stock turbo? I don't want to have to buy a new dump pipe as the one I have now I want to keep and I am a bit tight on money, but none of the gt25 or gt28's of the garrett turbos even come t3 flanged so my question to you is which one will fit the stock exhaust turbine housing and produce the most rwkw?
https://www.sau.com.au/forums/topic/226244-turbo-exhaust-exchange/
Yea but i am not in Australia and to be real the turbo knowledge here is limited and nobody highflows turbos here, thats why i wanted to know what garrett upgrade would basically take the stock turbine housing. Just a simple remove and reattach.
And? Ever brought parts from Japan? Same shit... Its called freight, and its not that expensive.
You want the best solution, its a hi-flow. Trying to butcher up a properly designed Garrett isnt going to work... and considering no-one hi-flows, then your never going to be able to get your stock housing onto a GTXX frame because it'll need machining either way and thats exactly the same process as hi-flowing. At least hi-flows have some information avaliable, butchering a designed Garrett is all luck and risk.
