Can someone have a look at the video below and tell me what's going on I believe the piston rings may be gone or something else. In the video there is epic smoke coming from the exhaust when I step on the accelerator and smoke coming from the oil catch can.
Car: R33 GTS-T Series 1
http://www.youtube.com/watch?v=4L-jUlbFX_k
Any help would be appreciated :miner:
https://www.sau.com.au/forums/topic/226344-r33-smoke/
Yea there has to be a problem because the ECU is a microtech and the answer for a problem is add more fuel but yea as for the catch can thats all it does is smoke and i dont want to run the car for to long in case a build up occurs and does more damage and its directly connected to the blow by hose using a t-connector thats the only line for the moroso catch can.
https://www.sau.com.au/forums/topic/226344-r33-smoke/#findComment-3986407
it could be your turbo my stagea dose the same thing took oil cap off and was smoken realy bad its being fixed atm and the turbos stufed.
you could take your air filter of and look down pipe to see if any oil down there,and maybe your cooler two.
thats if its even the turbo.
https://www.sau.com.au/forums/topic/226344-r33-smoke/#findComment-3992519
the rules for exhuast smoke are
black- too much fuel
blue- oil
white- coolant
so if you have a turbo problem it will most likely be your turbine wheel. but it is definatly fuelling up big time
Burnt oil is blue smoke, unburnt oil is black. So if the turbo's got a bung seal and its spewing fresh oil into the exhaust side, it'll look black.
https://www.sau.com.au/forums/topic/226344-r33-smoke/#findComment-3996032
  • 5 weeks later...
ur problem is a piston problem..... i had the same problem when i got high boost white smoke out exhaust...... opened dipstick and oil cap and smoke coming out....... one or more of your pistons has fkt up and thats whats causing it....... and the oil in the cooler piping isnt the turbo its the crack in the piston rings allowing oil to drip down into where exhause fumes are and spraying out ur turbo....... Mine got that bad that instead of my Blitz BOV release pressured air was releasing oil haha.... your looking at engine re-co if you get it done get forgies too extra 300-400 and well worth it
https://www.sau.com.au/forums/topic/226344-r33-smoke/#findComment-4062934
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
