Hey all,
Just bought some coilovers for my r32 a while back, ill leave the brand unnamed, and installed them all fine with a mate who has done them many many times before.
The fronts are great, sit very low, still have room to go lower....about 5 twists from being on lowest setting.
PIC OF FRONT:
Now when we installed the rears, on the LOWEST setting possible, it sat like this:
PIC OF REAR:
now obviously that shit AINT right. So i called the manufacturer, he asked me to measure the shock, so i took it all off n measured it, and they replaced the shocks with 2 replacement ones which were shorter. After assembling the new coilovers, we put them into the rear, and it was much lower, but still sits about 4-5 cm ABOVE the top of the tyre...on the lowest setting...
ive also put my rims on the car since installing the rear coilover, and im only worried about it now because the rear looks like a 4WD, while the front is dumped!
Pics of rear with rim on:
Now remember, this is the LOWEST setting, and with wheels that sit like mine, being that height just looks wack! I want it at least an inch lower (note the wheels camber in and tuck under the gaurds).
Do you think the replacement rear shocks he gave me are still incorrect? Does anyone else have a 32 that sits that high on coilovers on the lowest setting? i would have thought i would have a lot more play with the rear height...because at the moment it sits about the same height as STOCK...on the LOWEST setting.
Cheers guys.
https://www.sau.com.au/forums/topic/226488-coilovers/
what brand are they :D
:sick:
either the spring is too long or they still havent sent you the correct kit.
well the ones they originally gave me were wrong, hence the trade. When he replaced them with new ones he swore black and blue they are the correct ones, and even after showing him the pics above, he believes they are the right height!
https://www.sau.com.au/forums/topic/226488-coilovers/#findComment-3987766
sounds like he's just trying to talk his way out of it. If you arent happy, let him know, and dont accept his answer until you are happy that you have a product that you actually paid for. Going off that picture i would of expected the lowest setting to be simular from front to rear.
On the lowest setting, is there still plenty of shockie travel, or does it look like its sitting on bump stops? maybe its just a spring problem this time around?
https://www.sau.com.au/forums/topic/226488-coilovers/#findComment-3988184
yeah ride quality is still fine, pre load has been set correctly etc.
He isn't accepting that they may be the wrong replacements he gave me again and is swaring they are correct. He only replaced the shock part of the coilovers....i reckon the bottom bracket or something may be the wrong one?
https://www.sau.com.au/forums/topic/226488-coilovers/#findComment-3988402
They are obviously still wrong.
Your car is sitting at pretty close to stock height on the lowest setting. Just confirm it if you like, around 380 center to guard is stock, you look like you are around 360-370 still.
You can do a few things, 1 get a shorter strut (which is the better solution), 2, get a softer spring so it sags more under the weight of the car (i'd avoid this option as you'll be smashing bump stops) , 3, maintain your spring rate in a 50mm shorter spring and use a helper spring to keep the coils captive which should drop it another 30mm or so (while losing 30mm of shock travel in bump). or a mix of 2 and 3, slightly softer shorter spring with helper to drop it even further.
I'm assuming these aren't base height adjustable btw.
https://www.sau.com.au/forums/topic/226488-coilovers/#findComment-3988478
  • 3 weeks later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
