just wondering does anyone have or no anyone that has a r32 gts left hand side headlight and indicator light for sale if they do please msg me. i need them asap.
thanks cheers. matt
With 2 posts, you have not contributed enough to the general SAU community to be able to use buy/sell section, please dont litter the rest of the forum with rubbish, go and make some contributing posts and then use the correct sections.
As for Power to weight and on topic stuff, wasn't Vic law something like 100kw to 1 tonne, someone confirm??
B.
yea 125 per tonne.. now one more question; how do i tell if it's ADM or JDM besides just seeing if it's silvia badges or 200sx? I ask this because anyone can talk shit and i'd really rather not to get dicked for it later on.. and while i'm asking this how can the cops tell aswel? or in that somewhere in the vin or would they just check for compliance plates?
thanks guys
when the last time a cop actually checked your kw's with a dyno machine and then fined you cause your out of the power to weight ratio???
just make sure you dont drive like a dik and make sure your car is road worthy, like tyres, lights, windscreen, shit like that..
if it looks like a burnout car then more times than none you will get picked on...
I'm not talking about how powerful it will end up.. just the power/weight stock because some cops actually do know that say a gtr is illegal for P's and it's 3 points and a $1000 fine for 1st time caught.. so i'd rather just do the smart thing and avoid the risk.
but besides that there's no way for them to know if it's ADM (legal) or JDM (illegal)?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
