  • Replies 96
i have an update - i spoke to andrew from crd & he states the following:
- when u start the car the knock level can be distrupted hence the hand controller should always be reset after starting (u are right paul)
- if i hit rev limiter on the 1/4 mile this will also register a high knock level at times from noise etc when the exhaust pops & carries on
no need for a check with my tune - ready to go this wed night :D
yeah my clutch let me down but as paul explained "drag radials will always uncover the weakest point of the driveline"
from here i had a 'relatively lengthy' discussion with jim berry (LOL personal joke) & paul aka TWOOGLE!
my options are to either go with jims 'full monty' big single OR rebuild my existing twin plate clutch...both paul & i agree that i should stick with my twin plate which is the path i have decided to take.
im off to phuket as of tomorrow, as soon as i get back im onto my clutch as im keen to get out there ASAP & get kicked off the track :D
brett - as long your clutch is healthy (as i think mine had its fair share) your twin plate is perfect for your application!
good luck with your run & make sure u post your results on this thread, i'll be checking at an internet cafe :D
i did a short 2nd gear burnout then launched it @ 8000rpm - as soon as i got into top rpm of 1st gear i could hear it slip...2nd & 3rd gear did the same thing.
this is why i did an 11.7 but my 60' was 1.57 - there is still room for more improvement on my 60'
yep - i had a 10 in the bag
Id say he has a tune issue, or if he is using a fuel cut as a rev limit then it is self explanitory, should always cut ignition, not fuel.
Never had that problem ever, both of my gtr's never go over mid 20's even on 40c days running to redline many many times.
might be more of an issue that a piece of rubber was getting sucked up into his 044 intank pump and blocking it causing a fuel flow issue....nasty lean outs...ouch!
And you know you're trying your hardest when you lunch everything and try to take out one or all of the following:
- Your feet
- The car
- The track
- The timing system
- The officials
- The fence
- The crowd
Isn't that right, Ben?
:P
Mate their is no point calling up a tilt tray just because you have a slipping clutch or you snapped an axle - smash the damn clutch (and everything else) and THEN you have a reason to call a tilt tray.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
