Car: R33 GTS S2
Mods: rb25de Stock
Driving style: 75% Revs Below 4k 25% Showing Off
Driving conditions: Half Half of City & Freeway
Fuel brand: BP Ultimate
Ltr's for a full tank: 55-59
KM's per tank: 350-400
My Car Has Shocking Economy :banana:
  • Replies 46
Car: R32 GTST
Mods: RB30DET GT30r .82 @ 15psi; GTR injectors; RB25DE head ported polished & valve deshroud.
Driving style: Brisk acceleration always on a little boost with the occasional (at least once per drive) WOT
Driving conditions: Local 50-80km/h
Fuel brand: Shell 98
Ltr's for a full tank: 50litres
KM's per tank: 450km's (RB20DET used to get 470km's when it was running 1bar on the std turbo and std ecu)
New O2 sensor, New Z32 afm, recently flowed and cleaned injectors, no vac leaks and just a good tune.
Just dropped a set of 265/263 (221deg @ 0.050") 9mm cams in... Will be interesting to watch fuel economy plummet.
110 Inlet LCA; 115 exh LCA; 112.5 LSA so it idles smooth but just a bit deeper/throbs more and louder.
hahaha... As they say.. Keeping it real.. There's next to no difference between the turbo's and N/A's unless your constantly up the turbo of which on the street isn't all that often.
Nothing wrong with the dark side.
I'm waiting for some one to post a progress thread of a mean rb30de n/a or rb25de n/a - 12:1 static comp running on E85 loping like nothing on earth; thats really why I'm lurking. :(
Car: R34 4door - RB25DE - Auto
Mods: extractors and high flow cat - everything else stock/genuine.
Driving style: Soccer mum :whistling:
Driving conditions: 90% City 10% highway
Fuel brand: Shell 98 majority of the time, sometimes Safeway 98
Ltr's for a full tank: 65L (stock tank)
KM's per tank: not sure - I always fill up when i reach 1/4 tank. However I can usually do 11.8L per 100KM.
BEST consumption: 9.8L/100 (city) and 8.8L/100(highway)
WORST consumption: 14.8L/100 (city - I have no idea why?????) 9.2L/100 (highway)
Notes: Car has stock rear spoiler and weather shields, which could cause extra drag. 17" GTT wheels are wider than the stock 16" - this can also cause more drag - Tires are inflated to factory spec 36PSI.
Car:1988 R31 Skyline GX
Mods:K&N Pod, stock exhaust with a cannon + hotdog, 3degrees advanced timing
Driving style: 65% granny, 35% boy racer
Driving conditions: 90% city, 10% highway
Fuel brand: caltex 91 (or whicherver is the lowest rating)
Ltr's for a full tank: tank is 63L, always takes ~50L to fill up
KM's per tank: 400-450kms out of an auto which wont go into 4th gear until the engine is warmed up
Car: R33 Series 2 GTS
Mods:None
Driving style: Normal with occasional launch
Driving conditions: City
Fuel brand: V-power
KM's per tank: 600-650km
Ltr's per 100km: 10-10.4L
Car: '94 R33 GTS25
Mods: Catback exhaust
Driving style: boy racer, under 3k
Driving conditions: country town
Fuel brand: Shell V-Power (or BP Ultimate when shell shuts :D )
Ltr's for a full tank: 65ltrs
however, in other conditions
Car: '94 R33 GTS25
Driving style: granny
Driving conditions: straight highway (cruising at 100ks in 5th, 3k revs (drone-tastic))
KM's per tank: 700-750
interesting comparison here i rekn, more people should post up figures with comparisons like these :)
another thing, my fuel economy improved around town once id done a big long trip
Edited by G0DZLR
I'm waiting for some one to post a progress thread of a mean rb30de n/a or rb25de n/a - 12:1 static comp running on E85 loping like nothing on earth; thats really why I'm lurking. :P
you just wait.................... :laugh:
Car: r31 gx
Mods: exhourst, crazy timing, no cat and a pod...
Driving style: bita granny but mostly boy racer
Driving conditions: mountian range\city
Fuel brand: bp 98
Ltr's for a full tank: about 55ish L's
KM's per tank: 350km's maybe.. other day it got 670 with grandpa driving with minimal squirts
put it this way, how much power does your de 400/450kms per tank make? then ask the same of a det motor.
most skylines will make 400 to 450 kms per tank if it is nursed, but if thats all ya gonna do go buy a toyta echo. the turbo is there to make it fun.
my de makes 378bhp and does 300km to 45 litre of v power and shed loads of rubber smoke,caned all the way ,,,sorry forgot to say its a de+t but it still makes more power than a det at 10psi boost
Edited by lammy426
Well off coarse it will.. you've still got your high compression pistons then a turbo - not to mention you car is no longer a DE mate..
lol than who's DET in particular dood? what point are you trying to make?
:laugh:
its still a de its just got +t after it, its like saying its not gtr engine if you put a single turbo on it or its not a det engine if you put 2 turbo's on it,another angle it can't be a de if you put a supercharger on it or even nos.you could say its not an na any more but whatever you do to a de its still a de because thats just an engine model number/letters
A lot of us drive off boost often... mines turbo and i get 12L/100km so ~500km to a tank. Its all in how you drive it.
this might seem weird but sometimes i find that if i go on boost every now and then i actually get more kms out of it rather than just driving off boost all the time. :)
So, just to keep the NA boys happy with there good fuel economy.
Car: R33 GTS-t
Engie + Mods: RB30DET, valve job, small set of cams, light weight fly wheel, T04R + 6boost mani, Plazmaman FMIC.
Highway economy: 17L/100KM...
City Economy: 25L/100KM...
The ability to press the loud pedal and put myself in the backseat... INSANE... :(
Yes, that fuel economy is why as of tomorrow night, it won't have been driven for 6 weeks, and why it has also only been started for around 15 seconds a week ago.
Goes in for a tune in just over a week hopefully.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
