  • Replies 43
hey just wondering what yez think about this
i have the opportunity to get an rb20 with loom and ecu for 800
this good cause i think this is about what they're worth?
and i cant see a gearbox and other crap making up another 1k for a half cut.
the only other things you need are like gear box, drive sharft, brake master cylinder, gear box mount, new turbo, adj cam gears, fuel pump, injectors sorry got of the track a little. the other things (if you get them all together shoudn't be to pricy)!!
  • 3 weeks later...
