I bought a cusco tension bar and tried to install it last night. I realised that the Trust sump extension gets in the way. If the cusco has a bit more offset to the front it would clear the sump easily.
Is there anything out there that has more offset than the cusco?
Duncan, I was hoping for an answer mate and not more question lol :P
Duncan, the tension rod bar is a bar that connects the 2 front mounting points for the 2 caster rods. It goes across the car. It sits roughly just underneath the front point of the oem sump. Unfortunately it does not offset far enough forward to clear an extended sump.
Right-o, never seen one and never thought I needed one! Have you been having issues with the radius/tension rod mounting points moving? because it is a very strong part of the subframe they are mounted to.
We certainly get tight clearance between the extended sump and sway bar when putting the motor in, but everything is OK once it is on its engine mounts.
bummer! I have the cusco tension rod brace on my car and i'm just about to put in the crate motor with trust extension. are you sure that you're not able to rotate it? my tension rod brace doesn't sit below the sump, it sits in front. and the trust sump doesn't stick out any further forward, just downwards.
I had 2 go at it aldready Beer and it won't fit.
I wish that someone can show me a way.
I found a picture on SAU of what we are looking at
As you can see from the picture the sump sits roughly inline with where the front mounting points for the caster rods are. The cusco mount into the inside bracket of the caster rod mounting points. These mounting points are behind the sump. The cusco brace is offset to the front. It will clear most of the sump extension but not at the top of the extension. It would be nice if the cusco has a tad more offset.
Dunc, I know of someone, who is very fast on this forum, had to reweld the caster rod mounting point. The cause of the break is certainly unknown. I don't know what caster rods he has either. One would assume this would break, from ripple strip or during transportation, rather than the front mounting bracket.
well...thats exactly what happened to my car. I broke both side caster rods in seperate incidents. no sign of damage or stress on the LCA or subframe mounting, both times the rod broke where the studs go thru to the LCA. the front caster rod mount is very strong but also I would think under less stress because it is the pivot/lever point.
I had a different issue. Mine cleared the sump but not the whiteline sway bar :)
gtst not gtr though
I gave it to a mate and it is now happily sitting on his s13 track hack in my back yard and it clears the whiteline bar on that :D
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
