Don't happen to have the power window switch for the rear doors? Need one mainly for the rear left door as mine seems faulty.
yes i do, it's the silvery/grey colour. $30 plus postage
D.
  • 2 months later...
  • Replies 92
Posted Images
  • 3 weeks later...
rear bar, no.
collumn surround, yes, looks perfect to me, $40 plus postage
i have the front seats for sale, great condition except for one very small hole on drivers. make an offer.
also front and rear diffs, tailshaft, front driveshafts (from diff to wheels)
D.
Edited by pintaline
Excellent, that's the two pieces (upper/above column and lower/underneath column)? ...I don't suppose I need to check that it's in black? If yes to these please PM me payment info; postage would be to 5159
Thanks
DaveB
Gday, have you got the grey tiptronic selector cover, the grey cover with the PRD23 etc, as my clips are all broken. thanks.
and also the metal fuel filler tube ? thanks again
dave, yeh it's black. i'm flat out this week, will get onto a quote for you on monday
chook, yeh i have the cover but from memory it has a small scratch in the paint...? ill have another look and get back to you. if you're not fussed by that, $30+postage and it's yours
D.
D.
No worries Dave, I've got about a ~2 week wait on some locks (repairing damage from break in) to get here from Japland; so next Monday should be good :laugh:
DaveB
just checked the cover and it does have a tiny scratch but all clips are in good condition. fuel filler tube, $20
got front brakes?
calipers and discs? ship to Adel?
yes i have complete front brakes, calipers are good, discs are a bit worn, does anyone know the minimum thickness? i can have them checked and even machined if you really want
D.
12mm from memory, but could also be individual to the disc or vehicle.
Brake shop sould know.
Most discs (standard) i've seen have a little raised stamp somewhere ie. 'min-12mm'
p.s. Niiiiiiiice R31 in your pic! wish I still had mine :)
Edited by Stagea_Neo
lol cheers, i love my 31s... that pic was taken on the top of mt. panorama on an r31 club cruise, it's also a tv star... they were recording a bit about r31s for some show on fox and my car was one of the few they put in the show. sadly, it was written off about a week later by a hyundai excel. god damn excels!!! i have 2 other 31s at the moment tho, among other things...
D.
Hi,one question ,do you have the side indicators?are they the clear/smoked ones?If yes ...price? with postage to 3805,vic.?thanks...
calipers and discs, $150? and if postage isn't too much, ill chuck that in for free.
i had clear ones... but they went on my car. only a set of orange left. no cup holder either, putting that into another car
D.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
