I have the following for sale, IN Adelaide SA, can post some items but its up to the buyer to arrange shipping for larger stuff.
17X9.5 +17 Work Emotion XD9's in White with Maxxis MAZ-1 Tyres on front pair and Neuton's on rear pair, Great tread, rims all in good cond, slight scrape on one rim on the outer lip. Will fit on most nissans with Gaurd flaring/pulling or just a lip, depends on camber.
$1800
Whiteline Swaybar package for R32, these are a limited run with 27mm front adjustable and 24mm rear adjustable. you cant buy these over the counter as they are a special order from whiteline. (SAU Groupbuy) normal front adjustable sway bars are only 24mm front whiteline. I am firm on price, they cost me 550 and i havent had them that long. Best handling updrage i did on the car full stop.
$450 with links
264 Degree Cams and Cam gear package. These are direct drop in for an RB20/25. They are regrind RB26 cams from tighe cams. I have spec's of them which can be provided upon serious requests. They come with ISC Cam Gears (needed to achieve the best result as you have to dial them in and tune to suit) these are about 2000 kms old... As new condition.
$600
Thats all for now... i have some other stuff. All parts are still on the car so havent removed yet, however everything can be vouched for.
PM me or email HERE
https://www.sau.com.au/forums/topic/227122-r32-drift-goodies-see-inside/
  • 3 months later...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
