Hey Everyone!
Well it's finally time to get rid of the rest of my spare parts from my beloved 95 R33 gts-t (who now rests in skyline heaven)... :( The list of parts below are just the main things that I have, however there are many little bits and pieces available that I haven't listed which one may need for whatever purpose.. so just ask!
Inside..
Pretty much all interior panels, covers and vents..
GTR Dash cluster - variable colour --> Green/Indigo-Blue & adjustable light/dim (looks very nice) - comes with adjustable control unit - $400
Door trims - $80
Rear seat trim (passanger side only) - $40
Door rubbers - $20
Piller trips - $40pair
Sunvisors - $20pair
Rearvision mirror - $20
Vents - $15 each
Cluster surround - $70
Climate control - $30
Glovebox - $20
Floor mats (genuine Nissan) - $100
Front seats - $150 pair
Rear seats - $100
If you are looking for something that's not listed here.. chances are I have it, so just ask!
Outside..
GTR rear wing (series 1 r33) - $250
GTS-s rear skirt (standard r33) - $50
GTR side skirts (some minor skuffs - r33) - $180
Bolt on wing.. never used - $100
R33 Doors (small dint - one on each door) - $90 each
r33 Diff - $200
Rear suspension (including springs, arms etc..) - $180
Front rotors & calipers (with brand new pads) - $1100
Bosch 040 intank fuelpump & cradel - $200
rear lights - $120pr
Wipers - $35
Rear halfcut (includes both rear quarters, subframe, tank etc.. - $400
2 x 17" rims (9") - $140
Under the bonnet..
Hiflow GTS-t turbo (T3/T4) with custom 3 1/2" dump- suit r32&33/VL/SR upgrade - drop in replacement for R33 gts-t Turbo (T3/T4) - Has only run 1,000km since Hiflow - When running on the car, was dyno'd at 224rwKw @ 14psi - $850
Brake master cylinder - $100
Crossover pipe - $50
Clutch cylinder - $100
Go Fast Bits BOV - $200
Prices are somewhat negotiable as I really need to sell these parts soon as I'm leaving overseas in 3 weeks. Please just email if you have any questions about these parts, or any others, or would like some photos. Alternatively, you can buzz me on 0422 732 541. All the parts are located about an hour from Melbourne, however can easily be freighted anywhere in Australia very cheaply.
Cheers, Grant
Edited by downunder33
do you have the little driver side seatbelt holder out thingy?
and also interested in the brakes, but wtf $1100? did you mean 110?
Hey man,
yeah I believe I do have that.. I will have a look and get back to you regarding it. Might just take some time to find it! can you be a little more exact about the part? Is it the one the sits at about head height and is where the seat belt runs through to come back down across the body?
Regarding the brakes, that was an old price I had for all four brakes plus some other suspension towers and things.. i had just updated the post and didn't realise. did you want to make an offer on the front brakes? i haven't got a price yet but will check it more. what did you want cause i have the rotors, calipers, pads, everything.. rather sell it as a package.. let me know what you want to do,
cheers, grant
Hey, Got any pics of the gtr rear wing?
Thanks mate
hey Trav! yeah I do have photos except not yet. I'm in the process repainting a part of the bar, so will have those pics soon. whats ur email that i can send them to? cheers, grant
Hey bud, what does the bolt on wing look like? colour and size? thanks mate
Adam
Hey Adam,
The bolt on wing is a dual finned wing. It has two strut towers which hold it. They are aluminium and the wing itself is black and sits about 7 inches from the boot. Did you want some pictures? just pm me and I'll reply with them. The bar is adjustible too. Was looking for 100 + postage. Also have the GTR series 1 rear bar too if you're interested.
Cheers, Grant
