Ok guys, heres the story. Been working on my 33 last few months while it was getting painted. done things like replace all the vaccum lines and little bits around the engine bay.. last month or so my turbo has started coming to bits ie sounds like the bearings are stuffed. went to start my car today and it was running really bad so i drove my other car. got home tonight and discovered when the car was running fuel was slowly dripping from the join between exhaust and turbo.. :banana:. cant figure out whats going on here.
https://www.sau.com.au/forums/topic/227382-fuel-leak-from-exhaust-housing/
I would expect that if it is unburnt fuel it would almost certainly ignite as soon as it hits the exhaust manifold...I am sure you would notice this straight away...
Try getting a sample of it (only small) and igniting it with a lighter...obviously be very careful...alternatively check its SG but to do this at home you would need either a big sample or fairly precise scales...SG of fuel is about 0.7g/cc...Also see if it mixes with water...
put your key in the on position, undo the CAS and then listen very carfully while you turn the cas you will hear the injectors "clicking" as they open and shut. all six injectors should "click" with four complete turns of the cas keyway.
3 injectors squirt fuel per revolution of a 6 cylinder engine, the cams are a reduction to 50 %, thats why you need to turn the cas four times to fire all six coils and injectors.
Oil Check Ok.
ill try get a little bit of the leak and see if it light tomorrow in the light
As for CAS. not technicaly minded enough to go pullin stuff like that off so ill have to let that one go.
Any futher input would be much appreciated
probably not a good idea to drive it around if you think its fuel. does the engine sound like its missing, then it could point to a dodge coil? or it could be just overfueling, what ecu are you running? if you have you been cranking the engine lots without running it, you could have fuel in the oil. dump some of the oil and check it out.
btw. one complete turn of the cas fires all cylinders. one turn of the cam is two turns of crank. all cylinders have fired after one cycle of the cam or two cycles of the crank.
Checked the coolant? It could be coolant coming out through a weeping welsh plug.
I'm positive it isn't going to be fuel. Considering the fuel lines are all on the opposite side of the engine. And any fuel coming in contact with the hot exhaust headers would either ignite (worst case) or simply vapourise.
Ok guys so i got home from work and tried to start it and it turned over and stopped. so i thought instead of damaging internals it was time to start to take things off the car. stripped pipes back to turbo to check out the comp wheel to see if it was stuffed. was ok. took of the coils and checked them for visual damage.. ok.. so i took out the plugs. Then i disconnected the fuse to fuel pump to lower fuel pressure and turned the car over(probably not a good idea considering there was no compression)didn't think of that till after.. but in the process of turning it over i had a nice big spray of fuel come out of the 6th cylinder. tried it again and happened again..
So what you guys reckon, faulty injector. im leaning that way. by the way im running a SAFC could that be the prob?
Also while i got the coil packs off i was thinking i might test them. i know you have to test resistance but across what points? and what sort of reading am i suppose to get..
Cheers guys
Edited by Landy
yeah, injector 6 may be stuck open, or coil/plug for number 6 isn't firing. it sounds like there was that much fuel in the cylinder you got hydraulic lock, thats why it turned over once and stopped. and no, the safc wont be the problem as its only happening to one cylinder.
safc doesnt interact with the injectors, well not directly anyway. it plays with the MAF signal to trick the ecu into adjusting the fuel mixtures. if it was a problem with the safc you would see overfueling/underfueling on all the cylinders, not just one.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
