Are they N1 turbos to suite the RB26DETT?
If so, N1 Turbos came stock on the R34 GTR V-Spec II Nur's and stock max boost was 1.1 Bar = 15.9 Psi.
BTW I think you should post this in the Force Induction Threads. LOL!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4004158
nope no bigger versions - still enough detail visible to be able to cross reference turbos
By looking at the picture, The BNR33 and BNR34 have (N1) next to it and the BNR32 has (NISMO)...
(R32 GTR's came out in N1 Versions but I was never clear if it had N1 Turbos, but I read that the engine was upgraded to R32-N1 Specifications, hence the turbos should have been upgraded to N1 turbines)
Question is, in the picture, are they R32 GTR NISMO turbos?
Any different from N1 turbos?
NISMO made turbos? They might but are made by Garrett...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4006864
HKS make turbos ? They might but are made by Garrett...
Trust make turbos? They might but are made by Mitsubishi...
Apexi make turbos ? They might but are made by IHI...
Perhaps they simply named it nismo instead of N1 - do we know what N1 stands for? nismo is nissan's motorsport division (Nissan Motorsport International Limited)
use the pic as you will...
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4008061
Interesting. Thanks!
N1 maybe Nur Spec?
The R34 GTR V-Spec II Nur has a N1 Specification built engine in it.
Here is an overall idea,
N1 or Group N refers to a set of regulations providing 'standard' production vehicles for competition, often referred to as the "Showroom Class".
Ref - http://en.wikipedia.org/wiki/Group_N
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4009097
thanks for all the help!... those pictures help alot!
https://www.sau.com.au/forums/topic/227445-24u/#findComment-4010228
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
