  • Replies 51
Posted Images
That is probably the worst 34 conversion ive seen
Theres definitely some truth in what you say but i dont think the mud crabs care too much. It will probably fall off like a lepers dick as soon as they clout a barrier/gaurd rail etc so they dont get too precious about appearnaces. :)
fineline It will probably fall off like a lepers dick as soon as they clout a barrier/gaurd rail etc so they dont get too precious about appearnaces.
so long as the drivetrain keeps up it doesnt matter, it could help if it was one colour.
I agree with most of you after seeing these pics , it drifts like a champ this car, but it needs a pro spray job. It will be getting done later in the year or the start of next year depending on funds.
who cares..
important thing is...what motor is in it.. or a link to stats you've posted before?
its an RB25DET with 335 RWHP, we have a recent thread regarding doing the turbo upgrade here in the Queensland section somewhere.
aw man, then I'll have to get ANOTHER set of stickers!! geez.
gee, imagine how well Beau would go if he had a better looking car!!
oh hang on, motorsport (which is what we are really in to) is about how the car PERFORMS, not how it looks, silly me.
Drifting isn't motor sport.... It’s just a good theater performance and in Drifting the cars look and presentation does matter.
